I need to move and lighten up the load: I have many pulls outs all in good working order, others new:
Power Supply caps: (large cans: new old stock/ unused)
22000uF 100v Adcom caps x8qty ($19 each)
7400uF 200v AeroM huge mothers x16 qty ($18 each)
22000uF 35v Low profile ITT (about 2" tall) x18qty $5 each
33000uF 160v Nippon Chemi x4qty ($26 each)
56000uF 63v Nippon Chemi x2Qty ($15 each)
Power Supply Caps (Pull outs from working amplifiers)
Set of 4 Adcom GFA-555ii caps 15000uF 100v x4 $24
Set of 4 Forte Model 3 Aerovox caps 24000uF 45v x4 $18
Toroidal Power Transformers: Pull outs from well known power amps unless specified
Adcom GFA-555ii 60-0-60vac (115x2 prim) 700va metal can encased $65 each x8qty
Adcom GFA-545ii 40-0-40 (approx) (115vx2 prim) 430va metal can encased $39 each x3qty
NEW Small toroids 12-0-12vac 115x1 primary 60va $10 each x2qty
Forte Audio Model 3A 56-0-56vac (120x2) 700va $60 each x2
I have many other higher voltage Toroids e.g. 65-0-65 etc for 300-400watt (8r) power amps... let me know and I will scavenge through.
I reserve the right to list these on eekbay but would like to give fellow DIY'ers a first shot.
Thanks K-amps
Thanks K-amps
Price Reduction
Not sure if the prices are wayy up... here's a lil reduction to help out...
22000uF 100v Adcom caps x8qty ($15 each)
7400uF 200v AeroM huge mothers x16 qty ($15 each)
33000uF 160v Nippon Chemi x4qty ($25 each)
56000uF 63v Nippon Chemi x2Qty ($20 each)
Set of 4 Adcom GFA-555ii caps 15000uF 100v x4 $20
Set of 4 Forte Model 3 Aerovox caps 24000uF 45v x4 $15
Adcom GFA-555ii 60-0-60vac (115x2 prim) 700va metal can encased $59 each x8qty
NEW Small toroids 12-0-12vac 115x1 primary 60va $8 each x2qty
Forte Audio Model 3A 56-0-56vac (120x2) 700va $55 each x2
Yes they will fit. He has shown interest and tried to negotiate a price but we do not have an agreement.
Thus they are available.
I have fit these in the 555ii (not the older 555) using the 555ii's own clamps. Because it is the same Diameter i.e. 2.5".
However you might need to bend or cut off 1/2" or so of the bridge heat sinks that sit on top of the caps because the new caps are taller.
In the original 555, you will need clamps but otherwise it will work.
These were used in the 300wpc Adcom GFA-5802.
The GFA-585/ 5800 used 18000uF caps if memory serves...
