I doubt there will many with JX92 line arrays, although there is a JXR6 line array using 9 units per side, if you search the forum. An array of 4 would probably do most of us but even there the spacing between drive unit centres might lead to frequency lobing problems above 2kHz or so.
Colin said:I doubt there will many with JX92 line arrays, although there is a JXR6 line array using 9 units per side, if you search the forum. An array of 4 would probably do most of us but even there the spacing between drive unit centres might lead to frequency lobing problems above 2kHz or so.
I truly doubt that there are many Jordan line arrays out there. And if there were they would probably drive a Bently or the like and know the Kenedys personally ( i wouldnt brag about that).
The only reasonable array i can conceive of ( not counting Jims floor to roof array and sitting in the Fresnel zone) is a focused array. There you could get away with 4 drivers.
ron
ron
The current issue of HiFi News reviews the Aurousal speaker and doubles up to provide a (rather widely spaced) pair of JX92s per side. The reviewer didn't find any real benefits apart from available volume.
For a Jordan array, the best route is the JXR6 (when EAD get it back into production) which has been designed for this purpose.
- Full Range
- Big Line Array with Jordan JX92S
