BIB dimensions
Yes.
Closed pipes have peaks at its even harmonics and nulls at uneven harmonics with the 1st one damping the system at Fb [Fp] with the 3rd harmonic being approximately two octaves away and since the first one is so low, the 3rd is still a ‘biggie’. As you can see, the rest of the harmonic peak/null ‘train’ continues to decay away to near infinity [in theory AFAIK].
Of course some damping is required to smooth all this out and if a room mode peak/null should match up good enough with the speaker’s, then they can ~ cancel out at the Lp, so much less actual damping is required in practice.
In reality, what usually happens is that the room massively comb filters with highly resonant speakers and due to how we perceive the lower octaves it can sound much smoother, more coherent than an in-room measurement indicates.
GM
Well all the dims are posted here now. I'm not going to be able to build it at this time. WAF stepped in. Since I like to eat home cooking, well. Anyway hope someone will build one. She did ok a smaller project.🙂
Based on my T/S measurements, the BetsyK will provide great response in 76 liters BR. Tune to ~45Hz. F3/F10 44/34, models for flat response. HAven't built them yet so no further comments.
