As Kevin says, Duncan is all about guitar amps. For hi-fi, many people prefer to set higher quiescent current/dissipation than Duncan proposes as the maximum for each tube type.
What I find strange is the difference in results that I get from LTSpice, when trying different bias arrangements using EL34s in pentode-mode PP.
1. I find that the lower the quiescent current, the better the distortion behavior seems to be. In almost Class B (quiescent current about 10mA per tube), the harmonic distortion has fallen to zero.
2. With a shared CCS in the cathodes (i.e. strict Class A), odd order harmonic distortion is worse than in Class AB, and it starts to show up some 2nd harmonic distortion.
I just put these anomalies down to imperfect simulation. There are definitely quite a few things wrong with the simulation 'engine' in LTSpice, and this is probably just another of them.
