help needed to bias amp using 5881/6l6 tubes ,need to know what proceedure to bias for new tubes ,many thanks Blackarab.
Ok so see here a short thread where a knowledgable onwer gives the specific numbers for bias current http://www.diyaudio.com/forums/instruments-amps/202010-marshall-9200-a.html
I asume that there are resistors in the cathodes of the output tubes, if so measure the voltage drop accross the resistors at idle and adjust?
