Hey, learning as I go here. Can all transistors be tested the same. When I am looking at the bias stabilizer transistors (2sc1384) I get a reading of 592 from B to E and 770 from E to B. All the other transistors in main board test open and 600 roughly.
Using your digital meter and measuring a 2SC1384 --when OUT of circuit in relation to the base when testing =base to emitter + emitter to base when you REVERSE the probes -IE a reading in BOTH direction relevant to the base then that BJT is faulty .
I have a feeling you haven't done this ?
One direction should give a reading and the other open circuit when you reverse the leads in relation to the base.
Of course an analogue multimeter is the opposite way around to a digital one when testing transistors (BJT ) .
It is still in circuit, all the other transistors I checked in circuit gave positive reading, these two have not.
Best check is out of circuit with DMM transistor Hfe tester.
I have seen a transistor test ok with diode check but only have Hfe of 1 !
Rather than buy a hfe tester, I do a Iceo test, particularly on suspect output transistors & drivers. Bad transistors may resist 2 v of a meter diode test. 12 v supply or greater, a wall transformer is fine, 47 k resistor, series, series a DVM ma scale. Plus to collector of npn, minus to emitter. Opposite for pnp. Base open. current =12 v/47k (or 18 v or whatever low current voltage of transformer is) transistor is bad. Current 2 or 3 microamps, transistor is good to that open circuit voltage. My 250 vceo MJ15024 were testing bad @ 12 v, no need to kill yourself with 250 VDC.
Counterfeit transistors that might be good to 60 or 100 v, you may have to test that high. Don't use 2 hands on voltage that high, one hand at a time.
The $1 meter my coworker bought from Harbor Freight, which has a hfe socket, caused us to spend 2 hours disassembling a pipe (organ) chamber to check a solenoid, and 2 hours reassembling it when it was good. It wasn't the battery. He'd owned the meter for years. He was the senior worker.Even the cheapest of DMM's now usually have hfe tester.
Paid £6 GBP for mine.
No more $6 meters for me.
I bought my most recent $30 DVM meters from farnell, & Klein. Neither has hfe. The $10 more autorange models have, which waste a **** lot of time switching ranges when I'm trying to measure 3 to 50 volt test points. **** dancing numbers! I could care less for the 200 mv scale, which always comes first, followed by the 2 v scale. My reaction time is 56 ms, why wait for this 800 ms junk to decide what to do?
Mine works fine.
I tested it against a transistor matcher/curve tracer I designed and they were both spot on the same.
"Dancing numbers " ?
Yes I recognize that when I worked for BT ,while Digital meters have their points the ones I used courtesy of BT were useless for testing long lines as the RF pick up made the digital display look as if it was playing a tune.
I reverted back to an old school designed for BT analog AVO and that provided accurate testing .
Too dear for them nowadays but I still have my old AVO 8 MKV bought very cheaply from BT due to them "binning them " while switching over to digital testing from a central control.
- Bias stabilizer transistors
