I have read the Slone book on power amplifiers and have decided to build a class B MOSFET source follower output stage. This means there will be no pre-driver BJTs and I am not interested in any protection circuits(it doesn't have to last very long). The output stage must be biased with about 1v to turn on the two output FETs. The bias will be placed in the output of the VA stage. If I was using BJTs I know the bias must track the Vbe characteristic of the output(or pre-driver) transistors. I understand that the bias does not need to be as accurate as if I was using BJTs but what do I use to create the bias? Will a potentiometer work or does it need to thermally track some property of thr FETs?
Pwoida
Pwoida
