I have a three way speaker (poly natalia) with a KT88 se amp.
I want to built a GC for using with the bass speaker and use the tube amp for the high and mids.
What is the best strategy of connecting things.
Any suggestions for a tubed active cross over.
thanx,
Jaap
thanx,
Jaap
Jaap said:Any suggestions for a tubed active cross over.
some ideas.
http://www.t-linespeakers.org/tubes/xos.html
dave
The combination of sand for bass and vacuum for mid/treble works well, particularly when you find that most tweeters are 3dB more sensitive than their accompanying woofers, so you can match a 20W valve amplifier to a 40W sand amplifier. Given that sand watts are cheap, this is very useful.
