BG20 Horn Project
Hi all,
I have decide to make my first project. I choose full range speakers for easy connection purpose. No problem with crossovers etc. I have purchase two Visaton BG20 and waiting now for delivery. Two similar project I found online, both are horn/tube style.
I do not have accurate saw to cut board with necessary precision so need to buy with cut service, most probably from B&Q (I live in UK). Material will be plywood 18mm.
If you don't have an accurate saw i suggest you hire a carpenter to build for you. I did so and have no regrets, apart from wishing i had done so sooner and not made costly compromises on inferior designs. i'll keep an eye on the thread all the same as i also own that driver so it is of interest, not too many builds out there, good bang for the buck though.
I get some 18mm, hardwood plywood from B&Q, cut for size in the shop. Two boards (1220x2440mm) with cutting service, cost me less than £100. I gonna stored flat for a few days before gluing it together.
Reactions: LeifB60
Next day - next step. Holes for speakers are cutted. Should I use a gasket between the hole and the speaker? It`s gonna be a huge horn🙂
Gluing in progress. Plywood is not as strait as MDF. Have a problem with tension. Need few days to finish first box.
Reactions: Yurik_V
First enclosure are done today, need only fill the gaps and holes with wood filler. Now I choosing paint colour. I did a sound test, not bad at all🙂
To be honest, I had some problems with crimping. I did my best, using the tool attached on photo. I know is not perfect, but I was doing it for the very first time, holds tight. Soldering sims to be even more difficult. Besides, I have no soldering gun.
You should learn to solder. It’s really not that hard. Just experiment with a few pieces of wire. Just remember to heat the wire and let the wire melt the solder.
