BG neo8s DIY PDR'ed and used as tweeter
Yes, B&G planars have a big peak around 12k hz. And that is supposed to be a result of the perforations/wells.
Other than this peak, there is not much to correct in the FR.
And my observation of the peak; it is not offensive like the resonant or break-up peaks of some other drivers. You can listen to a Neo8S without correction and only thing you realize is somewhat more obvious/prominent cymbals in the music.
I EQ them with DSP before DAC.
However one caveat with planar/ribbon drivers: they are very sensitive to CO point.
Studiotech crosses Neo8S around 400hz. I found them too harsh down there.
My personal opinion on the neo8 is its a fabulous mid/lower tweeter, but needs some top end added. It might have enough top end for some, but doesn't cut it for me. As for the peak at its upper limit, anything I tried to tame it with, wether it was a passive notch or EQ, kinda killed what top end "life" it was capable of, and as stated it's not really as offensive sounding as it looks like it would be by the FR sweep.
