bg neo10 clone
The new bg neo10 coupled with a bg neo3 and a woofer should make a great speaker.
http://www.bgcorp.com/news.read.php?article_id=11
However it doesn't look like the neo10 will be made available to the general public.
Or maybe it will but with an enormous price tag.
I'm guessing anything under 100,- euro would be wishfull thinking.
I asume nobody saw them up close so the following question is ....well stupid is all I can think of.
What are the chances of a n00b building a clone of the bg neo10.
Maybe someone experienced did allready?
Something that will go down to 300hz.
It's possible. Get a Neo8 and reverse engineer it. Then make it bigger.
The hardest part will be cutting out the detailed foil trace pattern and adhering it to the kapton/mylar. A lot of fine work with an exacto knife would be required, and one slip and you start over. I can think of ways to make this easier, but still very labor intensive. Then you need to create a frame for the magnets and some sort of mounting / tensioning method for the membrane.
The key to the Neo8 (and 10s) is the close tolerances of the traces and magnet structure. They have managed to create a manufacturing process that maintains these tolerances at a reasonable price. Thus the price / performance of the BG product is excellent. It may not be worth DIY to save money. Only for the education and experience.
Etching the diaphragm would be a good solution especially if you wanted to do more that a few pairs. You might even be able to get prototype quantities from a Flexible Printed Circuit manufacturer. These guys have specs here: http://www.allflexinc.com/capa.shtml for etched polymide (kapton) down to 1/2 mil thick. I just don't know if they will do aluminum traces - copper is too heavy for planar diaphragms.
By the way, rumor has it that David Graebener of B&G has some new planer / ribbon drivers in the works http://blog.speakergeeks.com/index....avid-graebener-wisdom-audio-and-max-fidelity/
