no, one is supposed to solder the cable onto the wing thing. Does make sense when considering the whole connector with case and not just the metal inlay you are currently looking at.
Those connectors are stackable.
That might be it. The entire contact tube is split. If you solder the wire inside the tube that could stop the tube from flexing and making contact.
OK, the 'little wing' is described here as an 'external solder bucket'.
Hollow 4mm BFA Speaker Plugs | click4av
- Design & Build
- Construction Tips
- BFA bananas
