Beyond the Ariel
I wish I shared your confidence. Devices like the DEQX can precisely compensate for time, phase, and amplitude errors, leaving only issues with polar patterns.
The DEQX gets rid of the worst problems, but it doesn't make a speaker that isn't good on piano suddenly sound like the real thing. After correction, the speaker is less bad, but the piano ain't in the room yet. Same for vocals.
If the speaker has gross faults, like poorly chosen crossover frequencies, large phase angles between drivers, standing waves in the bass enclosure, or allowing drivers to enter chaotic-breakup regions, system equalization will not help. The faults will still be there, and a listener familiar with acoustic music will notice them as unnatural and artificial sound.
I don't find a "black box" approach to audio particularly productive. I take the opposite approach, working from the available devices outward, and letting the physical properties of the devices set the overall performance limit. Since loudspeaker drivers have many faults in many different domains, I pick and choose where to optimize performance. We are many decades away from loudspeakers that cannot be distinguished from acoustic reality.
Of course, you can't control for poor design. But all the things you listed, will eventually show up in the frequency response. Poor choice of crossover frequencies, less phase overlap through crossover, standing waves in enclosure, driver breakup, everything is revealed in the frequency response.
I'm not suggesting you EQ the heck out of anything and it's going to sound good. I'm saying you can have any sound you want ("slam" versus "clarity") by knowing how to manipulate the frequency response. There is no magic here. Of course, IMO, there is no such thing as "slam" and "clarity" because I've found that a flatter, smoother response allows me to enjoy a larger array of music, from the slam in "Smells like teen spirit" to the clarity of the piano in Chopin's ballades.
Since you've "been there, done that" I take your comments seriously. Chasing LF extension in a high-efficiency system is silly; Hoffman's Iron Law, and the 3rd-order power term in the T/S equations, are not going to be broken. LF extension is the domain of multiple subwoofers with powerful, restricted-bandwidth amplifiers. Class AB, or Class D, are no big deal if all you want is below 50 Hz.
Yup, look for the core-midrange quality with the horn and mid-bass - and then "add" from there on either end. I think that comes from my experience with full-range drivers (..something I pursued later after horn systems).
I sometimes think though that Hoffman's Iron Law could be "broken".. sort of. 😱 NOT extending below 50 Hz at any substantial near-average level, but rather modest form-factor and efficient.
My thinking is somewhat nutty here 😀 - but it "revolves" around the idea of a DML (or more likely a grouped mode version) grouping of panels which functionally are quasi-bipoles. Bipoles - and therefore no dipole cancellation = no pressure loss. Also, bipoles without the weird combing polar behavior of traditional bipoles.
A distributed or grouped mode loudspeaker isn't something I'd want to extend higher in freq.. but below 800 Hz it doesn't bother me from an objective perspective.
It's not something I've ever experimented with - so it's just a crazy musing. 😉
It would take around 64 series/parallel wired 12" drivers (less if mounted in a corner) to equal a single horn loaded 12. I think I'd rather drive one in a horn.
Bass horns are a thing of beauty.
Replacing horns with direct radiators can be futile.
http://www.electrovoice.com/downloadfile.php?i=970039
Just 2 B&C 12 PE 32's (similar drivers to the EV) in a 4 foot enclosure (total-both drivers) with a vent tuning of 45 Hz can provide an anechoic value of 98 db at 50 Hz and only -3db from there at 40 Hz.. (..granted it's a 4 ohm load with an extra 3db of voltage "gain").
However, 10-13 db more is quite a bit more, but I wonder what the size and form-factor is like for that added efficiency from the horn?
In any event, the point I was trying to make was with regard to a similar *sound* - not about which design will present the most amount of gain.
I'm sorry, I cannot agree with this. Here are two specific examples that are routinely encountered by loudspeaker designers:
1) It's normal for the bass or midrange driver to behave badly above the nominal crossover frequency. In the first system I designed (in 1975), the KEF B139 woofer had a monstrous peak at 1.5 kHz, in the range of 6 to 10 dB, and rather narrowband. The B139 was used as a near-subwoofer with a low crossover of 150 Hz, so the peak was substantially attenuated, and did not show at all in the overall frequency response.
The peak was very obvious on pink-noise audition, despite being some 15 to 20 dB or more below the in-band sound from the other drivers. To remove the peak from perception required either a sharp-tuned notch filter, or a 3rd-order crossover at 150 Hz (neither was cheap to implement with passive filters). If I remember right, I chose the 3rd-order lowpass, since it wouldn't need notch-filter tuning in production. (Both approaches sounded the same on audition.)
This was a real-world example of D.E.L. Shorter's "buried resonance" that evades detection with FR graphs. There was nothing imaginary about the audibility; flip the switch, and the mid coloration goes away, flip it again, and it's back. And Shorter was right about audibility on different program material: it was most easily heard on pink-noise, followed by massed chorus and massed string sections, and only intermittently audible on rock or blues. The sparser spectrum of rock or blues would only occasionally trigger the resonance, while broadband stimulus would reveal the coloration for what it was.
I've always followed Shorter's dictum of having the lowest possible subjective coloration with pink-noise stimulus, using other material to assess dynamics, imaging, or possible holes in the response. (The ear can acclimate to dips making a return to "flat" sound like a peak, so listening sessions need to be kept short.)
2) Since I worked with matrix quadraphonics before being recruited into speaker design, I was aware of the bizarre sound of 90-degree phase shifts spread across a wall. I was surprised to discover that 90-degree, or greater, phase shifts were audible even between drivers that were closely spaced. Once you train yourself to hear "phasiness" ... you start to hear it in many commercial speakers. At the time, the Daghlquist DQ-10 was the worst offender, thanks to many drivers with rough responses and low-order crossovers.
With theoretically ideal 1st and 3rd-order crossovers, the drivers have a 90-degree phase relationship. In the real world, drivers have ripples in their response, particularly at the edge of their passband (part of the reason for a crossover in the first place). The drivers are minimum-phase (in the usable part of their passband), so the innocent-looking ripples translate into phase deviations. At some frequencies close to the crossover frequency, the inter-driver phase angle goes beyond 90 degrees, and can approach 120 degrees.
This is partially visible as a slight dip the overall FR curve, but you have to sweep the microphone to find the real nature ... a deep null is close by, if you move the mike enough.
If you simply boost the dip region using DEQX or similar, that will not change the phase angle between the drivers. This is a very common fault in high-end loudspeakers. I hear it in many rooms at the RMAF and other trade shows; rough drivers with inadequate phase and amplitude correction in the rolloff region, which results in phasey and unstable sound in the crossover region. An MTM layout will partially disguise the fault, but walk around and you'll hear it.
Again, most audible with pink-noise, followed by mass choral and massed strings, with intermittent audibility on rock and blues. (If your music selection exposes design faults, don't expect to stay in the room long. Make sure to collect your disc from the CD player before you leave.)
These are just two, but very common, examples of design faults that make it into production on highly-reviewed loudspeakers that cost as much as $100,000/pair. There are many design faults that are beyond the scope of system equalization.
I know it sounds like I'm hard on the high-end biz, but many of the speakers with glowing reviews have outright design defects that are obvious to anyone that's designed speakers for a little while. Sure, the defects are correctable, but why do it for free for a company that is 100% sure that their product is the most wonderful thing on the market? They like their speakers just the way they are. Besides, they can always correct the defect and charge for the upgrade a year or two later.
These are just two, but very common, examples of design faults that make it into production on loudspeakers that cost as much as $100,000/pair, and are not obvious on the FR curves. There are many design faults that are beyond the scope of equalization.
I have a 8" driver that runs up to 10kHz without breakup or ripple.
And above 10kHz it does not fall abruptly in SPL response as most drivers do due to they are breaking up.
I also have a AMT driver that runs down to 100Hz.
When I change the crossover frequency between those two drivers I can get perfect measurements over a huge frequency (crossover frequency) range, but when listening it is the frequency that best matches the 8" and the waveguide radiation patterns that sounds best. So I have a 100Hz plus and minus range that are optimal.
.... You can get a similar result just by using more drivers of the same type (and of course with much more net volume to the enclosure(s)). (..each driver should be "broken in" individually.) The thing is - no one ever seems to use similar drivers in this manner, instead looking to improved low freq. gains from higher Qe drivers. Once you do that - different sound.
I have not seen any commercial turnkey solutions, but amongst the most dedicated Norwegian DIYers this is sort of a trend. The Altec/GPA 515 in multiples is a favourite.
http://www.diyaudio.com/forums/multi-way/195734-nelson-pass-slot-loaded-open-baffle-project-51.html#post3153175
This is a link to some pictures on the forum posted by a really adventurous gentleman who threads unknown water (backed up with decades of experience) with his all-out approach. With 10 GPA 515 alnico on each side you are approaching the sensivity of a midrange horn.
As I designed the concept for pengesluk´s SLOBS they do not need EQ to reach -3dB at 30Hz.
There's something weird going on with loudspeaker headroom, and I have no explanation for it. If a loudspeaker has excess (as in unused) headroom, you can hear it, even at low levels. And it's driver-specific; if one driver has 5 or 10 dB more headroom than the others, it jumps right out at you. Well, it does for me, I can't speak for anyone else. Maybe some people hear it, and others don't.
You can play a horn system at quite moderate levels, 50 to 70 dB, and it's obvious that the dynamics are different than a low-efficiency direct-radiator. If the direct-radiator is really low efficiency, like an MBL, or magnetic-planar, it's really, really obvious in the dynamic rendering, as well as tone color and shadings. It seems to take a locomotive to push these guys into sounding much like music, and even then odd things seem to happen to the dynamics ... you hear the loud stuff, but the little expressive wiggles aren't there.
The ultra-high-priced German and French systems that combine audiophile, low-efficiency direct-radiators with horn mids have a real problem here. The horns have one kind of dynamic rendering, and the direct-radiators have another. The character of the sound is different in different parts of the spectrum. This is truly bizarre and hard-to-describe mismatch, and it tears the music apart (if the music has an acoustic origin).
The ribbons crossed-too-low to direct-radiators have a subtler fault. Ribbons have no trouble above 8 kHz, but that's a range where there's not much tonality. The 2 to 8 Khz world is very different; plenty of tone and dynamics there, and mismatches are more obvious. Simply put, ribbons have very limited excursion capability, and go into peculiar inharmonic modes when asked to move too much. These modes have a very different sound than a cone driver, and the dynamic onset of this region can be quite abrupt. So the system does OK with quiet little tinkly stuff, but a dynamic swing from massed violins, or massed choral, upsets the balance and leads to a sudden flattening of apparent acoustic venue (not soundstage), as well as blur and hash.
After a while, the listener is tempted to gain-ride the volume control, to avoid the hardening of the sound. The great virtue of the old cone tweeters was they dynamically tracked the cone driver beneath them; the match was partly lost with the transition to dome tweeters, and not many ribbons seem to mesh with cone mids. One way around the mismatch is selecting metal-cone mids, but that has its own set of problems (very high-Q modes and violent breakup).
Say what you want about full-range drivers (and they have plenty of faults), but they don't do this. The sound is all one piece.
Aside from the technical considerations and manufacturer's specs, there's a subjective aspect to every driver. A big part of that are the dynamic limits of the driver; for example, the power-handling of ribbons drops like a stone below 8 kHz, and this is audible if you listen for it. In a similar sense, if the MF horn has 10 dB more dynamic range than the woofer beneath it, yes, it will be audible.
Part of what guides the selection of the high-pass crossover frequency for the AH425/Radian is the sudden onset of grain; that's the subjective experience of the diaphragm of the compression driver moving too much and probably creating turbulence effects in the very small compression region just behind the phase plug. Just a guess, but that's what it sounds like.
So there are clear dynamic limits with all types of drivers. Electrostats are beautifully clean until they're not ... and sometimes that's too late for the diaphragm. Compression drivers become grainy and harsh as the horn cutoff is approached. Direct-radiator cones drivers are very gradual in their overload characteristics, until the onset of gross breakup (cone cry). AMT's have a lot of punch in the critical 2 to 5 kHz region, far more than ribbons, but can get really screechy when they finally do break up.
The skill of crossover design isn't just flat response and good polar characteristics, but also avoiding pushing the drivers into regions they don't want to go, and that's a subjective assessment on the part of the designer. From what I've heard at the show, a lot of designers can't hear what driver overload sounds like, or perhaps don't care. From my perspective, the most important task of the crossover (active or passive) is keeping the drivers out of nonlinear regions, and everything else is secondary to that.
Could have written this myself. Now you are seeing why I am circumspect about horns ( there are other things) My portable FM radio produces surprising good sound.
I am not going to delve into the physics here. Perhaps you too have a theory.
By the way.I do not use headphones. Whether Stax or whatever. They sound great but of course you dont feel the music
By your own admission this is fixed with a steeper crossover. Once the peak is about 24 to 30 db down, it should not be a problem. This requirement is no different than the requirement for good phase overlap through the crossover region. You want the phase of the two drivers to overlap through the crossover until the output of both units is down 24 to 30 db. Agreed that this is not directly revealed in the FR, but is an important requirement of good design.
90 degree phase shifts are pretty nasty, especially if on-axis or near on-axis. Again, the outputs of the two units will just not add to flat if the phase is not overlapping. Off-axis, the units might go out of phase, but this usually causes dips in the power response that have been said to be fairly innocuous. With multi-driver systems, it is impossible to get perfect summing everywhere. Maybe with some topologies you can. Again, this is revealed in the smoothness of the off-axis FR.
Agreed. But again, all this is revealed in the on- and off-axis FR curves. Perhaps the only thing that is not revealed is how loud it will go without distortion. And that mystical thing we call dynamics.
Things like resonances 30db down or phase cancellation at extreme angles might be audible to some people in special conditions, but for the most part what you hear can be completely described the on- and off-axis FR.
Lynn, re post #9368
I like what you wrote there.
I's been in my mind for a couple of years, and I don't have a solution...
Most of us horn speaker listeners have written this dynamic coherence thing into our bibles. If we want a coherent sense of scale we use horns down to the lowest frequency. A "fully" horn loaded system - It's what makes the system whole.
The same can be said for the electrostat listeners, ribbon listeners and the cones and dome crowd. Make it fullrange or except the compromise.
How many people make the mistake of using horns with direct radiators then complain it isn't right? Electrostats? Ribbons? 🙄
Yes, but how low can you go ( hornloaded) , being realistic?
A lot depends on what space you have available, of course.
Use corners and wall/floor loading so the horns can be scaled down is about the only way unless you have a huge room. I'm in a concrete bunker that helps but still use a rear dual 18 sub (in a corner) with my front horn loaded 18 for below 50 hz.
Strong corners, floors, sidewalls, ceilings, all can be your friend with bass horns. Above 80-100 hz I don't like folds but have heard folded horns that sound great up to 500 Hz. They are rare but it can be done.
I haven't built a tapped horn but they do show some promise for tight spaces and bass.
It is quite true and I had to design and build my own drivers to get both low distortion, enough headroom and dynamic that appeared un-natural for some hours before I acclimatized. The un-natural part of it was that when a guitar or drums etc. "attacked" it was sounding like 10dB louder than clipping, but undistorted and clean.
My drivers have very high xmax, very little or no mechanical spring effects (pure silk surround and no spider), magnet system that are way beyond saturation of the steel - thus the ripple effect from the magnet system are much lower than normal etc..
I have to admit that I also needed Silver Mica decoupling of the power amps PSU and also Silver Mica in parallel with the capacitors in the crossover. From before there was Mundorf silver / gold in oil that alone was unable to do the job properly.
Due to that I use my AMT that have -3dB at 100Hz and can play realistic 110 - 120dB SPL from 500Hz with 6dB/oct filter and 300Hz with 12dB/oct filter.
I have tested most of the other AMTs, ribbons, planers etc. and also connected up in series / parallel up to 16 units only to discover that it was impossible to crossover lower than with one unit and that it did not help the fidelity to split the load either.
If I run the AMT without crossover at all as a broadband driver and uses a DC coupled amplifier I can play a good 80dB SPL and if a BHL cabinet are used the low frequency response are extended down to below 60Hz.
I have full dynamic and can play at the SPL level I prefer (80 - 90 average and peaks up to 100 - 110) with my 1 watt class A JFET SIT amplifiers.
A BLH folded horn with my drivers have a -3dB at 15Hz and AMT in waveguide from 500Hz and up to 15kHz where a super tweeter AMT acts as a 360 degree radiator.
The same drivers in a OB sounds much better and you totally avoid the problems the bass born creates..
Like the neighbors two or three floors above or under get serious problems with glass rattling in cabinets and vibrations.
I once fired up the BLH´s with 400 watt amplifiers and played well above 120dB.
No distortions was observed, but on the floor above the windows was rattling in addition to all other items..
Sounds fab...!
Ray,
Everything you are saying is " music to my ears " ....!
Your 8 inch cone and AMT driver combo in an open baffle design sounds like the best possible free standing full range loudspeaker I can imagine....
I have built a line array with eight 8 inch bass mids ( PHL) and 6 Beyma TPL drivers...it was fab, but not commercially viable ( driver cost plus DSP crossover) and being open baffle, it needed lots of space behind ....
Sold em to an Indian guy who had Apogee ribbons before, he loved them!
But your sounds even better...!
/QUOTE]
- 3db @ 15 hz? It must have been a very long horn path or were you using a corner? I always find back loaded horns suck the life out of the upper bass and low mid range due to cancellation from the back wave - front loading rules in the same frequency range in my book.
Open baffle bass to 15 hz with any bass driver sounds like an impossibility even at moderate listening levels. You must use like 20 of them (drivers) and probably in a big folded baffle?
