Beyma TPL Rear Chamber Experiments
I have noticed a number of people are running Beyma TPL's " open baffle" and with custom rear chambers. I have therefore experimented to see what the effects are of removing the rear compression chamber off my Beyma TPL's.
Bit of background - i am running mine in a custom "le cleach" expansion horn which are significantly larger than the standard OEM horns. The only noticeable effect was smoother roll off below <1000Hz. I am currently running them crossed @ 1200Hz and am looking at lifting this as they can sound harse. (I suppose secretly i was hoping the rear chamber experiment may sort out the harshness)
Attached below is a trace of the 3 configurations - all measurements taken from listening position 2.5m away. http://i1227.photobucket.com/albums/ee439/vinylnvalves/beymarearchamber_zpsd6bc79ca.png
The rear chamber i made had non-parallel sides in a 3:2:4 ratio with approx volume of 5 ltrs. I stuffed around 50% of this with BAF.
You can see the OEM chamber has the flattest response, i don't understand why my oversize chamber is so bad. Do i need to put back the felt on the back of the driver? Any suggestions on ways to improve the FR. I think they sound better without the chamber, but the loss of imagery outways this, so some type of chamber needs to go back on them
