Hello, I have been using Win ISD successfully for years now, but I have come across a driver that I dont understand, it is Beyma 15 b 100. This is the simulation on win isd - the graph if pretty much flat from 40hz to 2000hz but in real life it is flat maybe to max 100hz after that it gets much louder
Does anyone have any pics of this driver in boxes btw?
ok. The large box and tuning should raise the lower frequencies, which it does but not enough to mach the simulated graph
The scale isn't clear on the graph in the first post, but the sim is dropping off below ~180Hz. Perhaps the box needs to be tuned higher to get the FR even....
Could you please specifi more clearly what you mean ? Is it getting louder from 100 Hz when the frequency is lowered ? If yes, it is a question of wrong tuning. Is it getting louder with rising frequency ? If yes, it is probably baffle step.
Charles
WinISD is a tool to simulate how low your subwoofer-build is going to play and if the box volume/sealed/reflex construction has some effect on bass performance (hump/dip). All else is a straight line and has no meaning in real life, especially as a subwoofer is rarely used as a midrange/fullrange.
364 liters
25 x 10 cm x 11cm deep
as suggested by Win isd. Why do you ask?
Sorry, dimensions and volume don't match! Datasheets almost always show free air response in IEC baffle (size of which depeneds on driver's diameter).
Studio monitors usually utilize eq/dsp (mixing desk) and low end response can be adjusted for the room. If the box is bass-reflex, lower end is high-passed acoustically and low end can't be extended in reality.
That did it. I tuned it higher despite the simulation, now the low end can really be feltThe scale isn't clear on the graph in the first post, but the sim is dropping off below ~180Hz. Perhaps the box needs to be tuned higher to get the FR even....
I wrote the volume of the box and dimensions of port - like you asked. They are not supposed to mach because they are different objectsSorry, dimensions and volume don't match! Datasheets almost always show free air response in IEC baffle (size of which depeneds on driver's diameter).
Yes. I tuned it like this nowCould you please specifi more clearly what you mean ? Is it getting louder from 100 Hz when the frequency is lowered ?
Charles
now its fine
- Beyma 15B100 studio monitor build
