Better 12" Driver for this sealed sub?
Yes it's possible, but it's even more possible if you have it to sell it and use the money to buy better drivers and build an optimal sub. A better driver with a well designed port could blow that thing away! IMO passive radiators are a waste of money that could have been spent on a better driver, they are really designed to get low bass in a box that is too small to fit a decent vent.
What's wrong with the sub that you have now? Or, more to the point, what are you trying to achieve with the upgraded driver? A Morel driver in a pretty solid looking box, with a PR tuned to 17hz.sounds pretty attractive, what are you looking to gain?
Pete
I was hoping to get higher spl's below 25hz and deeper extension. The enclosure is rock solid and the passive radiator is a beast. But the driver seems wimpy in comparison.
Also, I guess I have a mild case of driver envy looking
at all of the awesome drivers out there 🙂
As far as the XXLS12 goes. How would I determine if the Morel PR
can handle it?
