Bestow upon me the virtues of MM vs. MC
MM or MC, which is better for what and why?
Also, how much thought goes into the magnet type, rather than ultimate field strength, in the Hi-Fi world?
Alnico, Ceramic, Neodymium...
For guitarists, the magnet type is something even beginners modding their guitar think about. Just wondering how much this crosses over in the Hi-Fi tonearm world. Makes a BIG difference to the sound of a guitar.
Neodymium - High output, brittle sounding (Thrash)
Ceramic - Lower output, less brittle, has presence (Rock)
Alnico - Usually the lowest output and warmest sounding (Vintage rock, like Van Halen & Hendrix)
I spent a lot of time messing around rewinding pickups, playing with the designs and magnetics. Makes me wonder how hard it'd be to try a DIY cartridge. 😀
Both and neither. The best magnetic cartridges I've ever used were about equal numbers of each. But all were very second rate compared to non-magnetic transduction- strain gauges and FM have quaities I've never heard in MMs or MCs. If I were going to diy, I'd look into those non-conventional technologies.
That's an interesting idea, kind of in tune with the original phonographs.
Peizo technology is still going through it's revolution phase so there's still a lot of improving being done.
I'll check it out!
Micro Acoustics used piezo transducers around 1980, MA2002e is probably the most common example. I have one, the sound is not highly refined but seems to work well with '70s rock records. I'd like to hear one of their models with microline stylus.
I had forgotten completely about the strain gauge cartridges. The Weathers FM was amazing in its time. It foundered on the inability to prevent inter-channel crosstalk when stereo came along, but perhaps modern materials would make it feasible.
And I think there is no single answer to MM vs MC vs Moving Iron. Cost, taste, associated equipment, designers' skills, individuals' budgets all make "best" too slippery to hold.
Konnichiwa,
This is a complex question.
First, any MM Cartridge (excepting the MI types often mis-labelled as MM) will have so much inductance that high frequencies are rolled off. The solution usually employed is to load the cartridge with a significant capacitance to create a resonance circuit to boost the treble up at resonance to partially compenaste for that. All in all suitable only for lo-fi.
An MC cartridge is considerably more linear, frequency response wise and otherwise, tends to have less moving mass.
Next is good to take the different types of styly into account. As long as the tonearm is of the traditional pivoted type, gentle elliptical and/or preferabbly spherical types are needed, extreme stylus shapes are not suited to pivoted tonearms and require linear tracking types to work correctly, preferably with remote controlled or at least easily adjusted VTA/SRA.
Sayonara
Paul Weathers broke his pick trying to "stereo-ize" the FM cartridge. He used a carrier frequency of about 100 MHz (???) and the (very small) capacitance between channels caused unacceptable crosstalk. He never did solve the problem. I'm not sure what modden technology could do. Lower frequency, and less modulation needed with current recovery schemes? I think at that time, the Foster-Seeley discriminator was the only demodulator available.
Moving magnets are not inherently inferior. For a long time, MC's had the higher moving mass, and all suffered from a peak at the high end, which in those days I could usually hear. That aside, MC's usually sounded cleaner; but I preferred the original Grado Signature (Moving Iron) to any MC; it was cleaner, and smoother yet. (Joseph Grado thought the MC inferior, despite his having invented and patented it. He received royalties on every MC sold in this country for some years. ) The MM ADC's were very good. You no longer see as a spec, moving mass referred to the stylus, as one could once. In those days, MCs either had substantially greater moving mass, or very low output. That was also the reason why MM's/MI's had better tracking at lower forces. And because the coil could be larger, the MM output was substantially higher, all things being equal. (This could be, and sometimes was traded off against inductance. ) And, as MC's have benefitted from magnet technology improvements, so have MM's.
Nowadays, the point is moot, as there are no high quality MM's being made that I'm aware of. The last entry, the Shure V15, is now out of production. I've had all three over the years, MC currently. (Piezo too in the very early days. Good ol' Sonotone, the student's friend. )
It might be interesting to try FM from the other direction- modulating the L. There's a moving-mass penalty, of course, but it might be manageable. It's also tempting to consider a design in a sum and difference mode rather than 45 degrees. Two different carrier frequencies with PLL demodulation? That would have been tough in '58, even for a genius like Paul Weathers.
The wooden arm was wonderful. Silicone damped, deader than dead.
! I think the two frequencies is a good idea, and should work. PLL's do seem like the obvious starting point, and I'd stick with the variable capacitance since moving mass was so very low.
As I remember, the arm was balsa. I'd forgotten the silicone damping.
Re: Re: Bestow upon me the virtues of MM vs. MC
Thorsten, isn't it the other way around? MM has a heavy peak around 8-12 kHz as it is and this is taken down with appropiate load in form a 100-400 pF // 47k or something. This peak comes from the internal inductance together with the cable capacitance.
Lo-fi.... maybe according to you. I'll guess this depends of which records you want to play.
Re: Re: Re: Bestow upon me the virtues of MM vs. MC
Konnichiwa,
That peak you refer to is the very resonance I refer to. However, if you only have the cable capacitance it should not be as low as 8-12KHz.
Classical MM's have around 0.5H inductance which with 250pF load gives 15KHz resonance....
Ever which way, MM's have not got any good high frequency response, even if loaded correctly and transient response (due to the resonance used to push up the drooping HF response) is very poor, which among other issues makes pops & clicks more audible than they need be.
Sayonara
Interesting debate. I don't know if it's lofi, or evenlofi, but I'm enjoying a lot mi Goldring1042 (MC) with my RB250 and a TD160. From what I remember, much better than the previously Blue point, and a yellow coral (both MC). I suppose money level has something to say.
Konnichiwa,
I also used to have a 1042 (and also the Reson Reca), they are okay, but a Denon DL-103 trashes them. The Sumiko Blue Point (special) earned long ago a black mark in my book as unlistenable.
Currently I have three MC's on my table, a Goldring Elite, A Denon DL-103 and an Ortofon SPU-GTE. The MM's (and other cartridges) are sitting in boxes.
Sayonara
Re: Re: Re: Re: Bestow upon me the virtues of MM vs. MC
The resosance is not something you add in order to "tweak" the frequency response. You have it by nature and capacitive load and resistive load can trim this peak. I'm not sure I buy your explantion about pops and clicks but it is a difference between MM and MC. I'll agree to that.
MC !
Konnichiwa,
Sayonara
Mine too...even the Shure V15VxMR did not last long, and was replaced by my personal favorite; Denon DL-304, wich I think is a bit more forgiving on arm-choice than DL-103.
BUT, it need above minimum quality on arm/deck to give good bass-response.
Arne K
