So I’m on plan for an amplifier that has 3 separate transformers (2x 150W, 1x 300W). Clearly I don’t want to press a power switch for all of those transformers without some sorts of soft start. The way the amp working requires the 300W transformer goes first and the after some seconds, the 2x 150W next. I plan to have a rocker switch at the front panel.
I wonder what’d the safest/most logical way to deal with the soft start and delay requirements?
check out
The ultimate Inrush Current Limiter Solution for large Toroidal Transformers
post 33 shows an unconventional approach.
Here is a trick. Get a Pyle power sequencer. Take the first three outlets and run them through a light bulb to the load, then the next three that sequence are direct feed to the first three loads.
Maybe Mark's board would suit your need... PCB: low voltage On-Off switch drives AC mains relay \ includes soft start .. H9KPXG
...I don’t want to press a power switch for all of those transformers without some sorts of soft start....
A mere 600VA of core? (Not even real power at start-up)
I'm on the end of a long power wire and I bang-start a 5,000 Watt (starting) motor all day long. I remember bang-starting 300W-400W output (600+ VA cores) Bogen, Crown, PhaseLinear, and ABSystems power amps. The Bogen, out in a park on a generator.
I found a suitable circuit and will have some PCBs made. Gonna need 2 soft start boards for my need.
According to the article, “Use of a soft start circuit is definitely recommended for 500VA and larger transformers.”. Is there a difference between one single 500VA transformer and 3 separate transformers with a total of 500VA?
Take your pick;
Soft-Start Circuits
- Power Supplies
- Best way to soft start 3 transformers?
