Best way to learn about crossovers?
I know a lot about speaker drivers and enclosures but crossovers keep killing me! How would you suggest I learn everything there is to know about crossovers and designing them, starting from the beginning? I wish there was a Crossovers for Dummies book, but there isn't 😀
I'm willing to purchase a book or software, whatever. If it's something I can read off the net, even better.
Thanks!
My best friend on this has been the pispeakers site plus a breadboard and some various components to actually _test_ stuff out on.
Reading all about it is one thing.. but its a different matter when you can hook stuff up to a driver, apply signal generator and listen to stuff work (or not work).
I found 3 articles from Rod Elliot go quite a way to explaining how the bits all work together:
http://sound.westhost.com/beginners.htm - Beginners' Guide to Electronics - Part 1
http://sound.westhost.com/lr-passive.htm - Design of Passive Crossovers
http://sound.westhost.com/parallel-series.htm - Series vs. Parallel Crossover Networks
Vance Dickerson's book gives a pretty good start on parallel crossovers
There's some fairly good software to play with on the FRD Consortium page: http://www.pvconsultants.com/audio/frdgroup.htm
I also found a pretty good spreadsheet (called PXO.xls by Murray Hauschild) earlier this year - but I'm currently unable to locate it on the web. It gave a fairly good indication of what happens when using different topologies and when inserting series components or Zobels in the crossover.
Then again, buying a few components and a breadboard (and with a careful hand on the volume control) you can have quite a bit of fun - but I'd read a couple of articles first, as tweeters can be expensive.
Enjoy.
