Best Valve pre-amp match for ME 550 amp
Sound quality is not affected though the unit may be more susceptible to hum and noise if you have very high efficiency speakers. See if you can't get rage audio or Peter Stein to send you a diagram. They ought to have them somewhere. Or you can post a high res picture and we can point them out..
OK, Ill get back to you on that - thanks 🙂
In the meantime, what do you think of the 2 pre-amp designs I put links up for??
...something worth noting: I got this cheap buffer pre-amp eBay Australia: Buy new & used fashion, electronics & home d?r
...and put it between the pre-out and main-in connections of a NAD Surround T773, and it is sounding much more life-like, transparant, and like a stereo amp rather than a surround amp.
Worth buying I reckon. Music is much more 'present' in the room, although I did modify it, I took the volume pot out, and hard wired it on max. I resoldered every connection with Munforf silver solder. I does make quite a nice difference, esp. regarding a greater sense of detail and life-like transparancy....
Hey, thanks for that - that is what I figured. A tube-pre would be just the ticket.
Do you suggest I remove the resistors? Would sound quality be affected? (where are they lol )
You should not just remove the resistors. The ME550 was different to the ME750, ME850 and ME1400/1500 amps in that it was capable of bridged operation. As such, merely removing the resistors will not provide a suitable high input impedance for your needs. The amp needs to be completely re-configured for straight stereo operation, thus removing the possibility that it can be bridged. And yes, sound quality is affected slightly. The amp has been specifically designed for low input impedance operation. Any changes will alter sound quality somewhat.
Or just find a very low impedance (ie: 400ohm) tube pre, such as this one: 12AU7 Balance Tube Valve Preamplifier Amplifier DIY Kit ref AR (No Tube) | eBay
No. Output impedance is still far too high. You should be searching for a maximum output impedance of around 10 Ohms. You could consider an ME preamp. They are superb performers, readily available and modestly priced. They exhibit a 2 Ohm (open loop) output impedance. Contact me via PM or email and I can assist you. I am in Sydney, if that helps.
The me-550 had a pretty usual input topography - the unusual low input impedance was set with a couple of resistors plugged into small sockets on the boards inside. Some people just cut or lifted a leg to give a more normal 50k unbalanced input that most things can drive. He used to have an info sheet he sent out regarding that.. Peter Stein's pre's were as powerful as little headphone amps (I used to drive my High impedance Sennheisers with them pretty happily.) but an all ME system, while about as dynamic as it gets, can be short on tubey warmth and depth of soundstage and plain listenability. A tube pre can be just the ticket to make low volume listening more satisfying and flesh out the acoustic guitar and vocals. I'm surprised Mr Stein didn't tell you though perhaps, like a lot of good engineers, he's better at answering the question you actually asked and not the one you *wanted* to ask. 8) I like ME stuff.. nicely made and great dynamics - very accurate, a lot like later Krell or Spectral. The 850 was pretty special with Apogees.
No argument from me there.
A lot of them (all models) blew up for various reasons though..
Oh really? Do tell? How many "blew up"? How many were sold?
The reality, I'm afraid, is somewhat more prosaic. ME power amps are about as reliable as any other high end, well designed power amp. Even better for consumers is that when a problem was uncovered, the manufacturer worked to eliminate that fault from any future amps. Thus, a consumer with a (say) 1988 version of the ME850 could have the 2006 enhancements fitted to his/her old amp. That includes the now notorious optical fan sensor.
they're not the simplest of animals and I guess that can be bad news for durability.
Bollocks. The cooling system can appear complicated to the untrained, but, in fact, ensures a much longer life for all the components than more mundane cooling systems. For instance, the cooling system in the ME550/ME750/ME1400/ME1500 amplifiers, draws air past the main filter caps (thus keeping them cool), then past the output devices. Thermal feedback from the output stages, combined with the tacho sensor on the fan/s ensures that the output device temperatures is maintained at a fairly precise figure (around 55 degrees C +/- 5 degrees C). This keeps them in the lowest distortion part of their operating curve and keeps thermal stress at a minimum.
Australia is also pretty harsh on high-bias power amps.. hell, it's not that habitable for humans a lot of the time!
True enough, but the ME uses demand responsive fans. As the amp heats up, the fans spin faster. Typically, on a 25 degree C day, the fans will be operating at around 200 ~ 300 RPM. Maximum RPM is around 2,000 RPM, so there is enormous cooling 'headroom'.
Have you bothered trying an ME preamp?
ME preamp = best audio product I have owned. Honestly I'd be getting a ME pre, and if you wanted to change the sound look at the rest of your system. Anways.
Re: ME550-Mk1 ... I was advised that I could just disconnect one end of a resistor to increase the input Z (no other reconfiguration of the amp required).
I did this, and FWIW did notice a change in the sound.
... with DIY its a work in progress..., and over time can end up with a rather good product; if you get better components etc: ie Ansar solid silver caps etc...
...I would like an ME though, at the right price...
...although I still want to work out a tube pre-amp solution: there must be a way to do it, and lower the impedance etc...
If you're trying to build a product as good as an ME preamp, good luck. You'll need several thousand transistors, in order to arrive at the right matching. The cost will far exceed the price of a new one. A good second hand one will cost you less than a good valve preamp kit. And you'll never manage the low impedance you need with a valve preamp, unless you resort to transformers. As for price, PM me and we can discuss.
So, how would transformers be used to manage a low impedance, assuming I was to build the pre-amp - 12AU7 Balance Tube Valve Preamplifier Amplifier DIY Kit ref AR (No Tube) | eBay - rated at 400 ohms: to bring it to the required 2 - 10 ohm range?
Is there any other way as well?
Someone seems a little invested in ME *me*thinks.. lol Anyhow, the impedance is just pro level 600ohm so any pro preamp designed to drive that impedance will be happy - (most hi-fi units will tell you what impedances they're happy with too in the specs) and yes, there was some reconfiguration besides the resistors. Turning the psu plug around (!) on one board. You know, I think these people would go a lot further toward giving people a positive view of their products if they weren't so obtuse about what actually was going on and trying to make service money. (My apologies if you aren't - perhaps I'm just overly sceptical) If you know (and it sounds like you might), upload the documents or description and help everyone! There are any number of capable people and they'd be delighted to have the info. For example; How about telling us which board (if it matters) to reverse the power connector on? Scan of instructions would be nice. Peter Stein did send those out on more than one occasion so I'm sure service people would have them. The reversing of the power connector put both channels in phase psu-wise and having them out of phase meant that you could bridge the channels (you can't do this one you put the amp into high impedance mode with psu back in phase) and also there is some advantage to bass transients coming off opposite rails allowing slightly greater dynamics in that config. I knew a man who distributed and repaired ME for many years and several owners so my failure opinions are anecdotal and not scientific certainly. Sadly the only people who could make a scientific study are people with vested interests so it doesn't make those accounts any more trustworthy. Perhaps we could make a poll sometime of owners concerning repair expense and failure. That would probably be more useful then either account. Careful of the fan cmos logic/counter chip - it's static sensitive and goes now and again. It's also socketed and on the fan board (pretty obvious as there's only one of those) If your fan goes full speed or stops with an error that might be the culprit. The service tech told me that lightening gets them (I don't see how) but hey. If you buy the amps online and get them shipped also check that the fans don't drop and jam because of being dropped by couriers. The impeller part is held in with a little cir-clip and occasionally fell down due to transit shock. Simple enough to put back after removing the sticker - same procedure as for lubrication if you've done that on sleeved units for pc's etc. Nice sounding dynamic amps. Pro's: dynamics, good low level detail for ss, good drive and openness. Cons: not particularly holographic soundstage (no way you can get that with low distortion though- it's an illusion coming from phase delays and harmonic distortion - read transformers and tubes or fets.)
I decided to go with this one for now. It will be a work in progress, and it seems to be a good design so far --- I have a feeling it will match the ME 550 well, given a few adjustments here and there...
http://www.ebay.com.au/itm/JP-200-J...mplifier_Parts_Components&hash=item4ab888e981
Any thoughts on the design? Also, schematics of 550 would be nice to have with regards to making appropriate modifications --- so if they can be supplied would be good.
I would still like to compare this once finished to an ME pre-amp... 🙂
Not that I'm insinuating reliability problems with the fan chips (I've had the same kind of cmos chip go in a Crown Powerline series (also nice and dynamic actually) and no-one complains about their reliability. In that circuit it was used as an error condition logic part and broken=error light and no starty. A pita but at least it only cost me $3.50 to fix as the schematic was freely available from Crown and that made repair easy and cheap. 8) That's the kind of support we like to see! There will always be companies that grind off part numbers (at least ME didn't do that to my knowledge) and don't provide schematics to owners. (Like Audio Research and Halcro - steer clear!) so think about what you're buying in terms of support too - we would if we were buying a car. The excuse that info in the wrong hands is dangerous doesn't wash with me. It's always better to be available to everyone. If one uses it and breaks the thing then you pay for someone who does know what they're doing or a dealer sanctioned repairer (if they're still around and don't cost more than a new amp - I bet those Halcro repairs are interesting now given the choice of repairers lol). As for building decent preamps, yes thats not too hard in diyaudio - plenty of matched quality transistors for sale cheap too. It's not rocket science. Impedance ratios of pre-out to main in are usually quoted as 1:10 as optimal with opinions varying slightly - plenty of info on the preamp building threads. Even 1:1 can work well for some people - like Mr Pass is fond of saying: listen and see! For the purposes of buying though.. Probably look for output Z less than 100ohms or get the info to convert your 550 to high impedance mode. No-one should charge you more than a minimal fee for lifting resistor leg and changing the plug around.
Im sure Peter Stein would gladly give this info, where I to contact him. He is not so easy sometimes to get hold of, but when you do, he is on a roll...I found him to be a very helpful person. Dont know what he might think of my idea, but to date I have found him an amiable and well-meaning chap. He modified the internals so that I could easily wire silver wiring to output as well. I just dont want to contact him unless necassary and cannot get the info otherwise (its painful trying to reach him). I had him refurbish and modify my ME 550, (including fan) and it worked like a charm when I got it; havent plugged it in since.
I really would like the valve sound hybrid with it though, as I have experienced just a simple but effective chinese valve buffer (which I modified a bit) in a NAD unit, between pre-amp/amp giving greater soundstage and clarity. Once I have achieved this, then would like to compare the ME preamp (or vice:versa - whichever).
I think either way, this would only promote the ME and probably initiate a greater interest with innovation in the product. I was using an NAD 7150 preamp out with the 550, and the sound was good, in comparison to the NAD stock amp sound.
So ANY good ideas with regards to mods are welcome and encouraged 🙂
The circuit will exhibit a hopelessly high output impedance (>1,000 Ohms), but you should be able to transformer couple it to deal with that issue. Also, it uses a loop feedback, which is not a great idea, sonically, given your ME550 eschews the use of global NFB. ME preamps also eschew the use of global NFB, as do most high end amps and preamps.
Have you costed the project? Using quality parts, it will cost a fair chunk of money. You could probably buy a nice, second hand ME preamp for the same money.
They were well designed products and sounded special - especially with low impedance brute speakers like Apogee, Thiel, Duntech, Ambience etc lots of control and dynamics where others amps could sound kinda muted and flat. Mr Stein is an accomplished designer certainly and the temperature thing does make a difference to dynamics and linearity. The ME15 isn't too expensive s/h. I see units go for 400-600 on ebay pretty regularly and the 25 for 800 or so with the phono stage. You can pay more for the latest "upgrades". Details of what exactly (components please if anyone knows enough to talk about them) they are might be would be nice else it's tricky to know what you're paying for of course. The 15 is nice enough (same line board) if you don't need two tape loops and phono. They (the pre's) also make a nifty headphone amp if you have high impedance (>300ohm) cans - with a very similar sonic signature to the power amps - dynamic and open and clear. A possible config might be source>tube buffer>me pre>me power to give you some tubey goodness. My unit also got a slight power hum when it was converted to high impedance operation (in only one channel) so be aware of that if you have silly efficient lowthers or something..unless you like humming.. 😀
How would you rate/compare this one: http://www.ebay.com.au/itm/320934868504?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
...also, what are the steps in transformer coupling with regards to the JP200
...and what mods would you suggest to help with the loop feedback?
(As I do this in stages, Its more affordable, and I end up using better components)
Once I build this, I still would like to try the ME preamp:installments work well with me ... 🙂
