Best use of these drivers
Hey,
I have 2 of these 8" woofers - http://www.advanceae.com.au/car/prod4.htm
I previously just had one of them in a 40 litre box tuned at 37hz, sounded great for music, really fast and tight sounding.
Since i have 2 now, what would be the best configuration to still get the same sound out of it (good for music, fast, tight etc), yet have a bit more volume.
Theyre rated at 100rms@4ohm each, and i have 350rms on tap.
Largest size box i could use is about 120litres.
Would i dipole work good ?
Any help would be good ! I know planet 10 probably has some good idea on a dual subwoofer !
Thanks !!
Yeh i was going to just make another sub to go with the one i already have, but if i make another it wont be able to be in as good a position as the single one i have now is 🙁
http://www1.jaycar.com.au/productVi...&pageNumber=&priceMin=&priceMax=&SUBCATID=443
That is the amp i have, it says nothing about being stable @2ohms, is there any safe way to test ? Just running it at 2 ohms and seeing if it works isnt really doable because i dont want to lose it :scratch:
Im sure someone with more experience than me could give me some help :bawling:
Postman I followed the link...that amp is not stable enough to run on 2 ohms so your option is to wire them in series and then you can tune the box to a lower frequency (twice the cone area)...you could port it if you want a little more output
thanks for your input joe.
Isnt isobaric just to get 2 woofers into a smaller enclosed or sumthing ? And you need double the power input ?
Wouldnt mind trying to make a dipole or push-push sub or something, but i dont really have any experience in designing an enclosure for them, or whether my drivers would be any good.
