Best temperature to solder germanium?
Apparently you can fry the component if you heat it too much so it's best to solder the joint quickly, I've read a 25watt iron is reccomended but somewhere else said it's temperature not wattage that counts?
Basically, would it be better to get a (probably low-budget) variable temp. iron or just the 25 watt-er? I'm just using it for PCBs for the near future
