Hello
I have a 8" sub driver that is being repurposed from a Logitech THX system. I have a Polk 100w plate amp I will be using with it. I am setting up a 2.1 system in my office which is 12'x18'. I have some decent custom MTM mains with tang band aluminum full ranges and tweeters.
The question is which box design would give me the best compromise between transient response and good LF extension to 30hz or so.....I have looked at T lines, Labryinth, and horns. Don't want muddy sound with no definition. Primarily for music, with occasional use as a Xbox gaming sound source.
Thanks for any help!
Greets!
Depends on driver specs, I mean it could be a driver that can't meet your needs regardless of box loading. In my limited experience repurposing inexpensive consumer woofers, well damped EBS, [ML]TLs are required. If it's a THX certified woofer it may already be close.
What are the various markings on the woofer? Pics may help too if you don't already have all the specs we need, XO point required.
GM
GM
IIRC, Logitech get their subs from Tang Band, so worth looking in that direction. Chances are it has custom T/S, so you'll probably need to measure to get best results.
That said, if it was mine and SPL wasn't a big concern, I'd put it in a sealed box and EQ the result.
Chris
Chris
You could look into horn designs by bfm like the table tuba. I’ve got a folded horn that’s a bfm and it does a kick drum like nothing else.
Peerless by Tymphany 830667 8" Paper Cone SLS Subwoofer
I Started looking at this recently. What do you think? I used tangband or Dayton ultimax8 for consideration as well
For an ‘all peerless’ 2.1 office/bedroom/whatever... mtms (drivers below) possibly too?
Peerless by Tymphany 830656 5-1/4" Paper Cone SDS Woofer
Peerless by Tymphany BC25SC55-04 1" Square Frame Tweeter
