I am looking to build a simple 50W i.c. based amp for a small Bose monitor speaker.
Out of the several chips mentioned here which is the most transparent and audiophile-like??......preferably without "SPIKE" protection circuitry that sounds horrid if overdriven.
royalmp2001 said:I am looking to build a simple 50W i.c. based amp for a small Bose monitor speaker.
There is a lot of discussion & experience over the Amp Chips DIY Forum.
There are also 2 active related threads right here:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=5018
http://www.diyaudio.com/forums/showthread.php?s=&postid=48953
What got me interested in these gain klones was a JoeList (heavily SE tube amp oriented) post on a chip amp one of the Joes put together. The amp got excellent review.
I have a pr of 1875 and a pr of 38xx something to try (free samples from Nat Semi)
dave
Of all the chips I've tried the best sounding was the LM1875, not 50W, but 20W or something. Check it out, also it's very easy to work with. Do indeed look over the amp chip diy forum dave mentioned, for there are some much nicer circuits then the one in nat semi's data sheet.
