Hi Experienced diyers🙂
I have ready on the table pcb's for F4,F5 and AlephJ amps with components but first timer like me esitate about choice to make for
pure and solid connections on pcb with solder
and between psu,rca,speakers with wire.
My questions is:
Your prefered solder is?
Silver,silver with gold,copper,leaded ,leaded free etc???
Your prefered wire for connections pcb's and psu,pcb's and rca
pcb's and speakers outs?
Solid core wire ,stranded,shielded,teflon,diameters please etc???
Hope Yours response bring help for newbies like me
My questions is:
Silver Solder - 10% Ag
and cryo silver wire
Silver Wire
ready for isolate with teflon or cotton.
Not easy choice so many foo priced like jevelery diy shops
but what in practic work and audio specyfications sound good ?
there are so many nice pictures of open original FW thingies
look at various threads , same as on 6moon tests/articles
list here : FIRST WATT REVIEWS
so - take a good look at pictures and use your brain , along with eyes
use proper industrial quality solder (Fluitin , for instance ) , 0,7-1mm dia
anything else is fifi mumbo jumbo
and yes - use 0,1mm dia silvered copper wire for input signal wires ...... 😉
for the non experienced I think 60/40 lead solder might be easier to handle
quality is not a question of which solder, but first and most a matter of final result
copper wire, just ordinary copper
and use the size that gives a neat result
look at connection points, and decide in each case what will be easy to do
its not meant to look like a fight
if it looks good it also sounds good 😀
For AndrewT
Eutectic 63 tin % 37 lead is preffered because it goes
directly from a solid to liquid state when melted(fragment from definition)
Strong point+up
Thanks AndrewT
For Zen Mod
Yeah!
Not jumbo stuff be necessary industrial solder like Flutin
be corosion protected and i belive this industrial guys have tested
them very strictly one+up
Great First Watt amps inside photos is a gold mining for dia yes.
I can learn lot about top quality class A circuit.
But please stop me a dream ZM😀
What gentlemans with shield wire and magnetic radiation
from Antek transformers
Its useful shield wire
Thanks for share first hand experience
Strong point+up
Thanks AndrewT
For Zen Mod
Yeah!
as AndrewT always sez - twist them , tight
however , I'm always finding amusing to put shielded mains wire , from back of amp to xformer
shield connected on upper ( at back plate ) side only
you can find proper shield in old VGA cables ( plenty dead CRTs around)
so - if you organize amp guts as seen on FW pics , no need for xformer shielding
though , if you find proper ham or beans can in local shop , eat it
then put it , but do not touch central bolt with it (which means very probable bzzzzzzzzpufff
"however , I'm always finding amusing to put shielded mains wire , from back of amp to xformer
(which means very probable bzzzzzzzzpufff )"
Thanks Zen Mod
Right i make it this in my diy amp🙂
Thanks Zen Mod
Stranded, but do be sure to tin the ends
first before you shape them to purpose.
I prefer tin/silver or tin/copper/sliver.
with a squeeze bottle of corrosive water
soluble flux. Yes, corrosive!
I prefer Kester 60/40 when drowning the
finished board in water is not an option.
The old fashioned multicore tree sap flux
is reliable, if messy...
Never use pure tin (SN100), its crap...
Never "no clean flux", crap on crap...
Keep solvents and alcohol away from
enameled wires, especially inductors.
Most water soluble fluxes have alcohol
in the flux itself. This might be the one
case where you would use a "no clean"...
I like Sn62 solder, 2% silver. Ersin Multicore is my favorite brand, mostly because I think their flux works better than Kester's. Radio Shack solder has particularly crummy flux.
"When solder melts and forms a joint between two metal surfaces, it actually forms a metallurgical bond by chemically reacting with the other metal surfaces. A good bond requires two things, a solder that is metallurgically compatible with the metals being bonded and good metal surfaces, free of oxides, dust, and grime that prevent good bonding. Grime and dust can easily be removed by cleaning or prevented with good storage techniques. Oxides, on the other hand need another approach.Oxides form on almost all metals when oxygen reacts with the metal. On iron, oxidation is commonly called rust, but it happens to tin, aluminum, copper, silver, and nearly every metal used in electronics. Oxides make soldering much more difficult or even impossible, preventing a metallurgical bond with the solder. Oxidization happens all of the time, but happens much faster at higher temperatures, like when soldering Flux cleans metal surfaces and reacts with the oxide layer, leaving a surface primed for a good solder bond. Flux remains on the surface of the metal while soldering which prevents additional oxides from forming due to the high heat of soldering.For many applications, the flux included in the core of the solder wire is sufficient. However, there are several applications where additional flux is extremely beneficial, such as surface mount soldering and desoldering. In all cases, the best flux to use is the least acidic (least aggressive) flux that will work on the oxide on the components and result in a good solder bond."
Like always intellectual understanding is far from put hands on.
Kenpeter thanks one +up
i try it experiment on free pcb at home
for Zen Mod
With today nanotechnology we never now i joke
but you are absolutely right 0,1mm solid core
for input audio silvered copper not pure silver
why if be not big buck and short?
Its about copper conductivity and musicality of materials?
Silvered protect against corosion?
yup
silver against corosion
tiny dia for sound
find screened Belden UTP cable - there is plenty of proper 0.1mm in outer screen
1m is enough for good
tiny dia for sound
Hi Mr dB
http://stores.acrosales.com/catalog/rosincore-EN.pdf
its look interesting and work with Ersin give clear
bright and solid fusion points.
Thanks for share
Thanks for share
Zen Mod wisdom make me fell
like japanis caligraph but i have solder gun
and point to point wired Son of Zen amplifier😀
with Belden
http://www.belden.com/pdfs/cable101/cable101all.pdf
Great!
with Belden
Great!
- Best solder and wire for Pass diy amplifiers ?
