Best SE KT66 schematic?
You could try something like this :note:
Never build it,just an idea 🙂
Mona
I'd probably go for a single 5842 as driver using either a CCS with led cathode bias or a 100H choke load with led bias (you may need to select 5842 or trim plate voltage to get plate current in a reasonable range) and cap couple to the grid of your KT66. I like fixed bias (not cathode bias) on the output stage..
