Which would be the best push-pull configuration for my 2 12" subwoofers.
Questions:
1) Which is better - (a) Push-pull with the subs on opposite sides, or (b) one sub on the side and one on the bottom face up?
2) On a push-pull configuration with a sub on the side and one on the bottom, Is it better to enclose the bottom sub with one side open (same side as the side-mounted sub), or is it be to have no sides/bottom to allow the sub's pressure to radiate in all directions.
Thanks for all the help.
Adrian
Questions:
Adrian
opposite sides and tightly coupled. If the subs have good linearity excursion-wise you might well find they work better just mounted push-push.
dave
dave
