Best Pre-amp to build for a new DIYer?
Hey,
Pardon "newbie" question.... but
I have a Rotel 990BX amp and 970BX pre-amp, and I'm interested in upgrading my pre-amp. Being short on funds and always wanting to build a pre-amp, this seems like a good oportunity to jump in and build one.
My question is: Should I consider building a "Son of Zen" pre-amp or maybe an Aelph P pre-amp?
Any suggestions for a first time build would be appreciated. Also, any recommendations for a PCB source is appreciated.
Thank you,
-David
My BoSoZ rund darned hot too. I think that it is higher current that makes for better sound, not temperature. If you can keep the temperature down, it will live longer. With the recommended heat sinks I measured 75C case temperature at +/-62 Volts on the rails and 80 mA draw per channel.
I built my regulators (one pair per channel) with 1x1x1.65" heat sinks - they run less than 50C, they would have been mighty hot with the heat sink called out in the article - about 4 watts if you use a single regulator for both channels.
there is another heat sink that is the same width as the recommended part, but has significantly longer fins(perpendicular to mounting face.) A couple distributors I checked had them. I'm waiting for delivery of some, I hope it is enough. if not, I'll rebuild with the bigger extrusions used in the power supply (and while I am at it change over to CCS).
GILMORE DYNAMIC!!!
Well, perhaps not for newbies. Originally a headphone amp, but can also be used to great affect as a preamp.
The PS is the only thing that needs heatsinks, and even then, four medium-sized to-220 sinks should do good. To cut down on heat a ton, you can safely downgrade the toroid from 35v to either 18v or 22v.
You can protoboard it or buy a PCB on Antness' page.
Around $200 w/ an alps blue($350 w/ a dact) to DIY it.
Does your Rotel amp have balanced inputs?
Because if it doesn't you don't need a balanced preamp.
Just go for the AlephL
Sure go for it.It is simple and outstanding sounding preamp (in my opinion sounds much better than BLS).
And you pretty much don't need to match transistors.
I'm refering to the first-all the time active version of L.
I didn't like the passive/active approach.
How big heatsinks are required for IRFP240 in Aleph P 1.0?
I mounted all of them together with PS transistor on a small heatsink and they barely get warm,so I suppose they would work with no heatsink.But thermally coupling both differential transistors helps.
Bartek
dw8083 said:
Hey,
Thank you,
-David
I am glad I have found this post, becuase I find my self in a very similar situation to dw8083, and thought that BOSOZ would be a great way to enter diy electronics, and in particular PASS diy!
dw- please let me know if you find a better source for the PCBs, other then the one you listed. It would be also interesting to hear where people get their high end pots and chasis, although passdiy site is very interesting in showing how creative people get in this reguard.
Thanks for the info!!
Etch your own boards! The artwork is in the BZLS write up. Lots of
people have reccomended Press-n-Peel PCB Blue Transfer Film on
this site Techniks
You probably won't save money doing it this way, but you do get
the "i did that" feeling, plus you have left overs for future projects.
I used the above to make my BZLS boards:
Everyone,
Thanks for the input and help! Greatly appreciated the useful ideas and suggestions to consider.
Well I decided to build the BOSOZ. I've already ordered a pre-amp and 2 powersupply PCB's from Kristijan in Croatia; at http://web.vip.hr/pcb-design.vip/ .
I'm expecting the boards next week, and will let everyone know if they are any good. The website certainly looks promising.
Moe, Thanks for the PCB etch website. I'd like to try it on my next project
Amo, I'll let you know if I find a good source for the pots or if Kristijan's boards look good. I have not found another source for a BOSOZ board.
Thanks again!
-David
Everyone,
Thanks again!
-David
