Best opamp for audio, operating at +5V only
I have a dilema and I would like to hear your recommendation for best audio dual SOIC opamp, running at +5V only. Not much is there to choose from, but I'm sort of torn between these there:
AD823 http://www.analog.com/en/amplifiers...mplifiers-op-amps/ad823/products/product.html
LM4562 http://www.national.com/pf/LM/LM4562.html
AD8397 http://www.analog.com/en/amplifiers...plifiers-op-amps/ad8397/products/product.html
AD823 got a bad name for being too harsh and flat sounding (and hard to get one), LM4562 is picky a like to pick up interferences, not to mention still being a bit too much harsh/sharp ... (but I have few at hand) and I did not know much about AD8397, except that it could be get as sample easily.
The opamp will be used as LineIn input opamp on my X-Fi. Replacing a MC33078 opamp.
So, guys, are any of these even better that the TI original MC33078? And witch one would you recommend to install?
Could be... how about these?
AD826 - slew rate - 350V/us, noise 15nV/Hz, supply 5-36V (CMRR 80dB)
AD823 - slew rate - 22Vus, noise 16nV/Hz, supply 3-36V (CMRR 75dB)
LM4562 - slew rate - 20V/us, noise 2.7nV/Hz, supply 5-34V (CMRR 120dB)
AD8397 - slew rate - 53V/us, noise 4.7nV/Hz, supply 3-24V (CMRR ~90dB)
AD8656 - slew rate - 11V/us, noise 2.7nV/Hz, supply 2.7-5.5V (CMRR 100dB)
OPA2365 - slew rate - 25V/us, noise 4.5nV/Hz, supply 2.2 - 5.5V (CMRR 100dB)
AD8022 - slew rate - 50V/us, noise 2.5nV/Hz, supply 5 - 24V (CMRR ~95dB)
AD8616 - slow rate - 12V/us, noise 8nV/Hz, supply 2.7 - 6V (CMRR 100dB)
