Which of the Beyma/BC models did you test and which of those were the best in your opinion?While Faital Pro is good/great IMO, when I was testing 10" midbasses (Faital, Ciare, 18 Sound, B&C, Beyma), the Faital's were the worst performing with regards to Harmonic Distortion (I tested a total of three different model Faital Pro's, not just one). They weren't terrible, they were still very clean with low HD, but the others blew them away for the most part.
I've tested the B&C 10PLB76 and the Beyma 10G40 thus far. If I had to declare a "winner" based on my numerical data and grading criteria, the Beyma 10G40 bested the B&C 10PLB76. I doubt I could even tell the difference between any of them, they were all within 1% of each other. Even then, it's interesting to see the data unfold before your eyes. In defense of poor Faital that it seems I'm bashing (which I'm not) the 10FH530 that I tested is one of the better values for what it costs, besting out other drivers that surpassed it, as superb performance of some of the others does not come cheap. I just have 1 more 10" midbass to test, and I will publish all my data for all 9 midbasses. I just have to wait for Beyma to ship their new beast to the States. 😉
Ya I tend to get Beyma at better prices then other. For me the main two options are Beyma or BC. I tend to like the Beyma products more but thats just an opinion with zero facts. Just what I have used before and was happy was all. But was looking at using a single 10"with TPL150 for a smaller 2way as a surround speaker. I have a pair of PHL 10"(3451) that I will be using to build a pair of center channels underneath the TPL150.
Was the 10G40 the new version with a published fs of 45 Hz ? Wonder whether it measured better regarding k3 in the midrange than what Beyma publishes in their datasheet.
Charles
Charles
Oscar,
Glad the 10G40 worked out well for you. Are your conclusions from the comparison based on measurements only or measurements plus listening?
For which frequency range?
Which of the drivers you tested did you like the best for midrange? Say 300 to 2000Hz.
phase accurate, I'll have to hook it up to the DATS when I get home today. I bought it used so I have no way of telling if it is an older or newer version, but the parameters will tell the story.
LewinskiH01, my conclusions are based on measurements only because they're all so close in performance that I can't tell the difference with my set of ears, so I have to no choice but to put faith in the data. (keep in mind that I am not listening to them full-range, but rather I bandpass them from about 100Hz to 1kHz, so some of the top-end FR differences don't have any effect). Thanks again for recommending the 10G40! 🙂
Here you can see it where I'm testing it integrating a Hygeia RT-62041 Planar Ribbon tweeter, crossed over at 80Hz/1,4khz. To my ears sounds great! And can get painfully loud!
For midrange from 300Hz-2kHz, I would [at first glance] recommend either the Ciare NDH 10-3 or the 18 Sound 10NDA610, based on pure [FR & THD] performance alone. But when factoring in costs (at least the costs that I found here in the USA), the Ciare NDH 10-3 is hands down the better value for the money spent. I will update my spreadsheets for that frequency range and send you a link in your Inbox.
Quite funny to see your pictures ! I have two older 10G40s that I intend to use in a 2x10" bass box. It is tuned a little lower than usual such that they don't bottom with my ERB.
Charles
Charles
Funny how? That's some serious gear in that living room right there! 😀
Tell me this doesn't look manly! 😀
I meant funny and not ridiculous !
You seem to play the bass as well and you seem to like the 10G40 as well, although I don't use mine for home listening. But I am maybe interested in the new version of these for an MTM.
The current MTMs are a little too "manly" for my listening distance:
YouTube
They were also a little too manly for the AGC of my phone.
Charles
YouTube
Charles
YouTube
Charles
I do a little of everything. 😉
Yup, those MTM's are very manly for a short listening distance.
Saw the new Beyma 8MC500ND. Looks very interesting for paaring with TPL150. Someone tested it yet?
Google did not find private measurements on the Beyma 8MC500Nd .
"Beyma unveiled a new family of woofers with patented Maltcross technology, with new 8, 10, 12, and 15-inch models, all with an optimized neodymium motor structure of very low weight. The concept for this new family is to achieve high efficiency in bass and mid/bass applications for high performance systems where high sensitivity, high linearity, low distortion, low weight and high total SPL are required.
The Beyma 8MC500Nd is a speaker with 2.5” coil, a sensitivity of around 98 dB, excellent power handling of 500 W AES and weight around 2.8 Kg. The new 10MC700Nd, 12MC700Nd and 15MC700Nd are 3” coil models, with sensitivities between 97 and 99 dB, nominal power of 700 W AES and weights between 3.6 and 4 Kg. Beyma’s Maltcross technology allows these new speakers a very efficient cooling of the voice coil, which reduces the losses by power compression and results in a more constant SPL, offering performance similar to models with larger motors and coils, which is an objective advantage in weight and performance."
The 8" Faital 8PR200 with 95db sensitivity and NdFeB motor produces a lower -F3 closed box crossover frequency.
From the SPL curve, both would allow a simple 2kHz crossover.
No, but I will be testing the 10MC700Nd when it hits US shores. I already have seen preliminary data on it, but I prefer to do my own testing, even with mediocre equipment, so it's on the same level playing field as the other testing I have done
Google is weak. What Google can't find, I can 😉
8MC500Nd FR & distortion, presumably at 2.83V/1m:
HD in the upper-bass/lower-mid range looks impressive.
Yes the 10MC700Nd is also a nice piece!
You will test it in combo with the TPL150? Anyway, please share your experience with it.
Not aware of these. From looking at specs, and from having looked at many 8" specs as midranges for TPL:
- B&C 8PE21 is rated 98 dB sensitivity, 0.5mH Le, 2.7 motor strength/Mms. Very well regarded midrange
- Faital 8PR155 is rated 97 dB sens, 0.41 mH Le, 1.4 motor strength/Mms. Very well regarded
- Faital 8FE200 is rated 95 dB sens, 0.44 mH Le, 0.8 motor strength/Mms. Very well regarded
If higher sensitivity is desired/required, 18Sound 10NDA610 (10") or 6ND410 (6") at 102 dB sens look interesting on paper.
My two cents, and going from specs only: the Beyma 8MC500Nd doesn't look better than these to me.
The 8PE21 is really good. I own and love them😀
I might test it with the TPL-150 since I have it anyways, but I will eventually test it with many AMT's.
Please bookmark/subscribe to this thread to be notified when I get to post up my final measurements of the midbasses alone:
War of the 10" Monster Midbasses!
Glad to read this.
Do you pair them with TPL-150H? Active or passive xo? At what frequency do you cross them to the tweeter?
Glad to read this.
Hi, yes together with the TPL in active setup. XO is at 1600 with 12 dB-LR. Sub is the B&C 15ndl76.
- Best midrange to pair with Beyma TPL-150
