Best material for atom storage box?
A focused far off resonance light field in a vacuum is probably the best container for atoms. A 100w CO2 laser off ebay might do the trick, depending on the kind of atom of course.
If the question is indeed veered towards an Atom processor board, a box made of MDF or Birch multiplex lined with copper foil could work. Or some box from Hammond, they have a wide variety of cases and boxes from cheap to expensive. You often can even choose between metric and imperial screws.
Thx for the advice!
Yes this is for multiple atoms.
The laser solution is interesting but need the box to be non-powered for reliability reasons, though I would make an exception for something like a Slaver stasis field which would be quite acceptable.
Haven't you heard? You only need to round neutrinos up tomorrow if you need them today.
Extrapolating from that, you obviously only need to THINK about needing them (since this is tantamount to needing them tomorrow), and they will be there. Today.
No Scrinth required - that's soooo last century technology
QED
Of course, they may or may not have a cat with them...
Atoms have CPU boards? Wow, ten years of chemistry education and that never came up.
Well, they only now just manged to use the best supercomputers to model a simple atom. Perhaps they should have studied the atom mobo first, for some hints. Might have cut down on processing time. Some atomic version of assembler, I'm guessing.
