Best looking preamp
Thanks ACD,
This case is build from 2mm stainless steel and the knobs are massive stainless steel. Turning up the volume or changing inputs is a little bit like opening a big safe. It is all pretty expensive and very vulnerable to scratches but I am happy with the result. Plans for matching cases for a CD-player and DAC are currently on the drawing board. Yep, DIY is so much cooler than consumer grade stuff.
I have some time ago downloaded this picture of a possible preamp chassis, however I can't recall from where :(
Does any of you know the manufaturer ??
