Wonder just how much it is?
NEC NL10276BC12-02
Display area 129.02 (W) × 96.77 (H) mm (typ.)
Diagonal size of display 16.1 cm (6.3 inches)
Drive system a-Si TFT active matrix
Display color At input signals for data of RGB: 8bit and FRC: High
16,194,277 colors
Pixel 1024 (H) × 768 (V) pixels
Pixel arrangement RGB (Red dot, Green dot, Blue dot) vertical stripe
Dot pitch 0.042 (W) × 0.126 (H) mm
Pixel pitch 0.126 (W) × 0.126 (H) mm
Module size 178.8 (W) × 126.8 (H) × 12.0 (D) mm (typ.)
Weight 265 g (typ.)
Contrast ratio 500:1 (typ.)
Viewing angle At the contrast ratio 10:1
• Horizontal: Right side 60° (typ.), Left side 60° (typ.)
• Vertical: Up side 45° (typ.), Down side 60° (typ.)
Designed viewing direction At DPSR= Low or open: normal scan
• Viewing direction without image reversal: up side (12 o'clock)
• Viewing direction with contrast peak: down side (6 o'clock)
• Viewing angle with optimum grayscale (γ=2.2): normal axis
Polarizer surface Antiglare treatment
Polarizer pencil-hardness 3H (min.) [by JIS K5400]
Color gamut At LCD panel center
40 % (typ.) [against NTSC color space]
Response time Ton (white 90% → black 10%)
6 ms (typ.)
Luminance At 5.0mArms / lamp
250 cd/m2 (typ.)
Signal system LVDS 1port (Receiver: THC63LVDF84A, THine Electronics Inc. or
equivalent)
8bit/6bit digital signals for data of RGB colors, Dot clock (CLK),
Data enable (DE)
Power supply voltage LCD panel signal processing board: 3.3V
Backlight Edge light type: 2 cold cathode fluorescent lamps
Replaceable parts
• Lamp holder set: Type No. 63LHS01
Recommended inverter (Option)
• Inverter: Type No. 65PWB31
Power consumption At 5.0mArms / lamp and checkered flag pattern
4.9 W (typ.)
NEC NL10276BC12-02
16,194,277 colors
Weight 265 g (typ.)
6 ms (typ.)
250 cd/m2 (typ.)
equivalent)
Data enable (DE)
Replaceable parts
4.9 W (typ.)
Third edition of the datasheet at NEC site
300:1 CR and 21 ms RT mentioned here
You and me could build a really small projector with this one and with shorter FL fresnel for collimination and maybe a glass lensfor condensing the image for the projection lens. Seems also that the picture scanning can be reversed (no mirrors needed). Use with DE 150/250W HQI lamp and Epia-M & DVD-ROM.
Price, where to get that? If someone could by a whole stock of them he could sell them for us for less...
Yeah, a small lcd with top notch specs would solve a whole DUNGLOAD of problems...Or at least make things heaps easier.
http://ne.nikkeibp.co.jp/english/2000/09/0904nec_fpd.html
says the sample price was 9/2000 100.000 yen.
100,000 Japanese Yen = 748.391 Euro / ~ $
Maybe you can get it now for 1/2 less, that's still quite a lot 300-400 EUR/$.
well it would fit strait into my projector, mine built for a 6inch lcd and that screen should slide strait in!
Trev
Trev
Got a price quotation from Displaze, £430 pc. (about 650 EUR/$) Too expensive for me when compared to TFT monitors. Pulled LDVS pane + Kontron APG card would be the best solution. I think the APG will cost about 100 - 150 EUR. Too bad most pulled LCD's are too slow (>50 ms RT ~ tr+td) and have usually the contrast of about 200:1. Of the most inexpensive TFT monitors the Samtron's 51S 15" have quite good specs too: 330:1 CR and 25 ms RT for half of the price of the NEC 6.3" XGA LVDS panel.
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- Best LCD/TFT panel for DIY projector (without controller)
