Shure there are a lot of people with huge amount of expirience.
So ca we chose the best of best
or just the best for certain conditions horn
Must work at list from 3.5k
good dispersion on Hights
flat... (no or lo drop on hights)
Now the best i found e-jmlc 1000 wich is wide and quet flat
but it drops down 12db from the midrange part to the hight
(dont shure its horn maybe it is driver bms 4538)
Driver radian 465pb
Driver radian 465pb
You've seen this thread:
http://www.diyaudio.com/forums/multi-way/212240-high-frequency-compression-driver-evaluation.html
right? That should steer you in the right direction.
EDIT: Oops! You are looking for a horn, not driver. Well, I do know that those horns work very well and are priced well. As they are close to you, shipping should not be too bad.
wouldnt surprise me if it sounds better that way
