Best Hookup Wire? (for component internal wiring)
Do you have ANY basis for this assertion??
Mistrusting all off-cuff opinions, I got some data. In the kitchen. Potato is fresh. Indeed you do want a higher impedance. 101k is "high" for modern Hi-Fi.
We also see why we dislike Aluminum (best conductivity per buck)-- it is hard to get a good long-lasting *connection* on Aluminum or on a potato. The number kept changing. On an Aluminum termination I could try higher clamping force; on potato that just makes mashed.
Gut instinct from enough electrochemistry experiments. 🙂 Good to know I wasn't out to lunch! I probably would have eaten the potato if so.
This is great, thanks for doing that.
Cheated? Cause life is unfair? Or cause common engineering knowledge has little relevance to any product above midfi level?
Hearing is really not so hard, it only requires the ability to suspend pre-established dogma and open one's mind. Do it for yourself, no one needs to know 🙂
There's a whole lot of expectation bias in this realm.
The standard mythology of wire/cable in audio tweakery is that it must be something exotic and probably expensive or it will totally screw up audio signals...so how can it be that RG-59 with its copper clad steel center conductor works just fine for cable TV signals?
Mike
I wish i could live in your tidy, logical universe where common engineering dogma explains everything and there is precious little to be discovered, well, certainly not in audio, which is just trivial. I really do 🙂
But if i did, i would then have to look for another hobby as who wants to explore the trivial and mundane?
You do. Look around.
Any change is sound out of the speakers MUST be the result from a change in signal through the amp (unless you embrace the concept of ESP, in which case there would be very little to discuss, so I leave that aside for now ;-).
So if that mains cable changes the sound it means it changes the signal as a result of more or less mains junk.
Proper design can make sure that doesn't happen.
If changing the mains cable does not change the sound, congrats, you've got a great amp! Keep it.
Jan
I am now testing my setup with Brandrex Cat5E shielded solid wires cable. 2 conductors for signal and two for neutral each conductor either signal or neutral are taken from each twisted pair and soldered together , the foil screen is only connected to one end neutral.
The sound is clean and powerfull but also a bit laid back in clarity.
So now will test with awg20 silver plated copperwire Teflon insulated wire, 2 wires for neutral and one for signal twisted together.
This is for interconnects one meter long pair, sorry if for wrong thread.
For internal and very short wiring of 5-10cm there should not be any big difference in sound quality using standard wiring.
Best regards
Does the impedance of Cat5e cable (100 ohms?) is changing anything if a bit long as between a pre and a source for instance?
I'm surprised at this point nobody asked about the potatoe variety for further experiment!
I'm happy with Hook-up wire between AWG 24 to 28/30. Although 24 AWG ha my preference when cooked al dente.
Of course YMMV
That is the characteristic impedance, which comes into play with wavelengths that are the same order as the cable length. Those are at the frequencies that normally go through cat5 cable - many MHz /GHz.
If you measure them with an ohmmeter you do not measure 100 ohms (much, much less).
So no, no issue for audio.
Jan
Thank you,
Does this characteristic impedance matters for audio digital or clock signals please ? (let assume clock speed <50 Mhz)
What type of hook-up wire would be ok between two boards for such signals please ? Anyone, cause we always try the shortest length or impedance matching between those two boards should worry us ?
🙁 I still can hear some difference whith cables after my amp (always had cheap ones though)
Thank you,
Excellent point, indeed! That is why you would use 50 ohms cable, and the input impedance of for instance your DAC also being 50 ohms (or 75 ohms in some cases for AES/EBU signals).
By matching the cable characteristic impedance to the source/load impedance you make sure that the signal is least distorted even with longer cables. The measurement for this is called 'eye pattern' - there's a Wikipedia for it.
The cable characteristic impedance is determined by the combination of cable capacitance between conductors and the cable inductance along the conductor, plus a few other factors. Very roughly, the ratio of L to C determines the cable 'impedance'.
But again, measure a 50 ohms cable with an ohmmeter and you will NOT measure 50 ohms. A tiny fraction of it.
Jan
I see so much diy dacs with digital signal input vias than I was a little puzzled...(I2S vias or SPIDFvias with no conector footprint)
Yes I do know a wire is not a resitor (at least it is but as you said not in that high ohmic ranges 🙂... btw still use the ohmmeter to buzz and hear if the signal is going through my bad soldering joints)
Do sweet potatoes sound warmer?
