So I am new to this, but I am planning on building a quality pair of speakers powered by an AB amplifier. The material of the cylinder will be thick aluminum. My budget for each driverranges from 20-150$. The only issue is that I don't know how to judge drivers apart from cost. I am trying to achieve the best possible sounds from 5 inches.
Option 1 would be a quality full range speaker
Option 2 would be a smaller 2-way configuration.
The tweeter would be around 1 inch and the woofer would be 3.5 inch.
Option 3 would be a coaxial driver like this one
B&C 4CXN36 4" Professional Coaxial Speaker 70 x 70 8 Ohm
Kind of depends on your design objectives. Personally I'd opt for a quality full range and make a 2.1 set up
Welcome to the forum!
I like the look of the coaxial speaker, but mainly because it is the only one whose specifications you have made available.
https://www.parts-express.com/pedocs/specs/294-6048--bc-4cxn36-spec-sheet.pdf
In common with other 4" speakers, the bass resonance frequency is high (94Hz) so it would require the addition of a subwoofer for anything other than desktop use.
You would have to determine the internal volume and mode of operation (sealed/vented) of your pipe enclosure in line with the published parameters of the speaker.
Since you say you are new to this, I have to ask if you are familiar with Thiele/Small Parameters.
Thiele / Small parameters explained with real world cases
Ok so I did study that article. Thanks for the help!
As opposed to the coaxial, here I found a full driver
Dayton Audio RS100-4 4" Reference Full-Range Driver 4 Ohm
The frequency response is greater 80-20k
The coaxial is 95-18k and much more expensive
So why go with the coaxial?
A tube with 5" outer diameter means that you must have a speaker driver that can be fitted in the end of it - so nominally a 4" driver. In that size there is no real benefit of using a coaxial, unless the unit will be part of a 3-way speker with separate bass unit.
The benefit of a tweeter comes from it's smaller diameter and therefore wider dispesion of high frequencies above 5khz. The area of the tweeter is off from bass-midrange driver's surface area, which greatly harms bass capabilities in this size range.
A round 5" baffle gives no support for bass, so the poor 4" driver will need 6dB of boost below 1kHz! Do not expect much better sound than a table radio gives... A high quality speaker design is extremely difficult bunch of restraints and compromises in this size! A dsp helps to get sound balance right, but distortion in bass can not be avoided.
I don't know if it is the best ;-) but I like it a lot HX 10 - 4 Ohm | Visaton
I don't know why they don't have written on web site that tweeter is soft dome made of textile which I like 🙂 so I do recommend it. I have been using it for a few yers now and it is still great.
Worth a read - looks like something that can be adapted to your size pipe - unless you have already got the pipe and you can then use this as a cosmetic outer and sleeve with the plastic pipe.
LXC - cdenneler
LXC - cdenneler
- Full Range
- Best driver types for a 5 inch diameter cylinder?
