I'd like buy a pair of good 2a3 triodes for my home made SE amp.Need advice which brand is the best (exept the Emission labs, 'cause it's expensive) of current productions 2a3-s?
Shuguang treasure or 2a3C with graphite anode, TJ, Fullmusic of Sofia mesh anode? Or another choice?
Thanks for help!
Thanks for help!
Add the Sovtek monoplate to your list of possibilities. It's quite decent in the sonics dept. and it will tolerate dissipation levels that destroy NOS.
I'm not sure if monoplate is something different from what I tried but I've had a problem with Sovtek 2A3. Its current draw may be more than what their spec shows which exceeds the current handling capabilities of the regulator I was using for my SET amp. As a result, it dropped out of regulation and passed hum through to the output tubes. When switched to different 2A3, the hum was gone.Add the Sovtek monoplate to your list of possibilities. It's quite decent in the sonics dept. and it will tolerate dissipation levels that destroy NOS.
I'm building a SET amp right now that will use the Shuguang 2A3C tubes. I've heard a lot of great things about this tube. The cost should run you $80-$100 for a pair (bought mine on ebay). It looks like they use to be cheaper but, like everything else, has gone up in price. Still not a bad price, though.
I just bought my OPT last night. I went for a James JS-6112HS. It was in the right price range and was just enough for either 45s or 2A3s. I later found out that the next biggest James model- the JS6123HS is a much better OPT, but also a bigger jump in price. We'll see how they do.
When I get things up and running, I'll let you know my findings.
Matt
Matt
I am very happy with Electro Harmonix 2A3s. They are well made tubes and reasonably priced. Check Partsexpress site for current pricing.
I'm using a pair of JJ 2a3-40 's. They sound very good, and I got them cheap. (30€ /piece)
However, just for reference, I'm going to order a pair of TJ meshplates. I never heard another 2a3 in my amp, so I'm curious about differences. Its going to happen in a month or so, if you want i'll get back here, and report the differences.
gr. Paul
gr. Paul
- Tubes / Valves
- Best current production 2a3
