Best computer S/PDIF Out?
You might consider C-Media CMI8738 based soundcards. These do digi in/out very well (without resampling as opposed to SB Live and Audigy) and also support 5.1 digital passthrough.
I personally use Leadtek Winfast 4X
True 24 bit operation
I would take a serious look at the Digital Audio Lab CardDeluxe. It is a two channel card with up to 24 bit digital in and out and is true 24 bit with either left or right bit stuffing for the unused 8 bits in the PC 32 bit data stream. Multiple cards can be run together in sync mode. There is also a module available to add fiber optic input and output.
The design of this card is about 4 years old and the card has excellent performance. Its maximum sampling rate is 96khz. A link to this card is:
http://www.digitalaudio.com/
Some of the RME 8 channel units may aslo be worth looking at. These use external boxes for most of the electronics to get around the internal noise problems within a PC.
A link to these is: http://www.rme-audio.com/
John Fassotte
Alaskan Audio
[Edited by alaskanaudio on 12-01-2001 at 11:24 PM]
So I bought a SoundBlaster Audigy..
And I can't for the life of me figure out how to get 6 channels from it. The digital port has nearly no documentation, so I have no idea what sort of jack to plug into it to get my sweet sweet digital. If Creative Labs' website and support wasn't so horrific I wouldn't have this problem.
Ignite,
I presume you want to connect your SB digital signal to an external DTS (ie 5.1) decoder via the SPIF port.
In the SB website, http://www.soundblaster.com/support/faq/ the FAQ section has a brief description of what you need (cables, connectors, etc.). You need a mini jack to RCA cable (mine came with the sound card) or you can get one done easily yourself.
If you are talking about the digital output from the header connector, all you need to do is send an e-mail to SB's technical support, they will send you the information.
