Best amplifier board (100W + 100W) (<50$)
Depends on what power supply you have.
If you don't already have a power supply, a 200W PSU with the required voltage(s) will add a considerable amount of cost relative to that $50. A 50Hz transformer with huge capacitors will cost much more than $50. Also high voltage PSUs are more expensive, so are PSUs with both +V and -V out.
Tripath amps can run from a single-polarity power supply and being bridged they need less power supply voltage for the same output power compared to non-bridged amps. Hence the flooding of low-end market.
