I am not sure this is the best forum for this, but...
I have a Beolab 3500, "mk 1" with MCL and Masterlink inputs. I would like to run it from an phone/tablet. There is a company that makes an iPod adapter cable, so it can be done.
Does anyone know the connections for the B&O MCL 7-pin DIN socket?
Thanks for any help.
HIFI4ALL Forum: Bang & Olufsen club
According to the image:
3 left
5 right
2 ground
Pin numbering is 6 1 4 2 5 3 7 when looking at the male connector and going counter clockwise.
3 left
5 right
2 ground
Data Link 7/7 pin A/V cable full wiring:
pin 1 - output, left
pin 4 - output, right
pin 2 - shield, signal ground
pin 3 - input, left
pin 5 - input, right
pin 6 - data ground
pin 7 - data link
pin 3 - input, left
pin 6 - data ground
pin 7 - data link
Thanks for the reply’s. I want to go straight into the speaker without using a Beolink like what is shown on that hifi4all link.
I tried pins 2, 3, 5 last night, and was not impressed with the result, noisy and low volume from an iPhone.
2 was tied to the connector shield, don’t know if they need to be floating?
I’ll try that when I get home later.
Okay, made progress.
It is looking for a balanced input.
Pins 1 and 3 are left channel, pins 4 5 are right channel. Running those signals from a single ended source kills the noise on that side, and i get "music"
2 seems to be ground.
Ill wire up a plug and confirm.
- Beolab 3500 Aux input
