I noticed last year that the first two channels on my PMH3000 had intermittent crackles on them when using phantom powered mics. If dynamic mics are connected and the 48v switched off all is ok. All other channels are fine even with phantom powered mics.
This year channel 2 has got much worse and is completely unusable with the 48v switched on.
Has anybody else had similar problems ? I have disassembled the unit and tried to swop the larger capacitors around in the front end (between ch2 and ch3) but had no joy at tracing the source of the noise,
thanks
gary
thanks
gary
Does anyone have a schematic diagram for the input stage of a channel on this mixer to show the phantom powering ?
I've got an MX802 circuit, but really theres very little in phantom powering - just two 6K81 resistors feeding 48V to the input pins.
Perhaps the coupling capacitors from the input to the ampliifer are leaky?, they have to block the 48V DC.
