Behringer EUROPOWER PMP518M-need schematic
Hello.
If someone happens to have the schematic for the EUROPOWER PMP518M, power mixer from Behringer and is willing to share it to me, I would be very greatful. I need the schematic for the power amplifier. I'm missing some traces on PCB so the repair without the schematic is nearly impossible! Thank you in advance!
Is the little power amp the LPA1180?
I can't provide the schematic, but other Behringer models also use it, so when using Google to search for the schematics, you could also look for PMH518, BXL1800, K1800, and the LPA1180 itself.
One place that has a number of Behringer schematics online is Electrotanya.
I did not have problems with theese resistors. They can be bent aside, to get the screwdriver between them. They are radial type 5W resistor mounted on some longer leads. The real pain are copper traces. If you overheat the pad just a little, good bye solder pad! :Ouch: And I have to remove 4 transistors, 2 diodes (15V zeners are baked) and 4 resistors. I managed to replace all resistors and make contacts with broken copper traces. Now I only have to get 15V zeners and IRFP140/9140. Then hopefully the amp will work!
