First post here!
I have a failing PA amplifier I've started to attempt to fix. I'm studying electrical engineering, but never really worked with audio amplifying circuits so I'm in need of some help.
The issue is such: After about 30 minutes or so of amplifying, the output degrades to clicks. I can tap the cable to get some noise but no amplifying of an actual signal.
My completely ignorant view of the circuit makes me suspect it is a shot FET, as I see about 7 FETs lining rather large heat sinks. As soon as the FET takes on to much heat (after about 30 minutes) it fails.
I'm curious if the problem is common, or if there is an obvious solution. Any help would be great.
Thanks!
Thanks!
