Hello wourld 🙂
I have a question i nead help advice or some thing.
Tinking of bilding my own amp , tinking of using some of the tda chips.
It must be hi-fi 12v dc power 10w to ..
And will a swiching power suply do🙂
Switchmode supplies have a bad reputation in DIY audio for various reasons. One reason being people being stubborn and reluctant to change. But there are good technical reasons why one wouldn't use a switchmode supply in an audio amp. But that's not saying that you cannot use one.
If you can find a switchmode supply that can deliver the needed voltage and current, you're in business. If not, then I recommend that you start with a transformer, diode bridge, and reservoir caps like everybody else...
I do *not* recommend that you try to design or build the switchmode power supply yourself.
Well i thought of this as a power suply
and it says for the tda that it neads -12 +12 and the atx power suply gives only 0,8 A on the -12.Will it be enough and is it HI-FI Quality.
well i got a power supply runing 12 v 10A 🙂
And for the lm1875 runs on -+15 on the data sheat and the standard atx gives only 0,8 A on the -12 out pot will it do?
And when i said HI-FI i ment hifi Quality on some chips datasheats it says hi fi and on some doesnt so is it inportant?
Tnx for the reply-s and sory for my bad english 🙂
You can run a LM1875 on single supply, if you can tolerate the dc blocking capacitor on the output.
What if i buy one of this it is class t i hear it is ok
There are four that are in play
You help me pick an is the t class any good copared to ab class
MKll Tripath TA2024 fully finished&tested pcb 2x15watt on eBay (end time 26-Oct-10 03:09:58 BST)
2*15W @4? Tripath TA2024 D-class Audio Amplifier Board on eBay (end time 10-Nov-10 08:54:06 GMT)
New Version MKIII Tripath DIY Audio TA2024 PCB on eBay (end time 29-Oct-10 02:19:02 BST)
Classic T digital TA2024 amplifier ? optimized Version on eBay (end time 24-Oct-10 09:12:41 BST)
- Chip Amps
- Beginner Amp
