Bedroom speaker build (with renders and questions...)
Hello all, first time poster here. (ulp...)
I had posted this question over at AVS Forum (my usual hangout), but found this forum which seemed far more appropriate. (and active for the DIY crowd)
Hello all! I've finally decided to take my love of all things audio and do something I've been meaning to do for years... build my own pair.
I want to start with as simple a project as possible (from a technical standpoint) so I've elected to build a pair of speakers to put in my wife and I's bedroom that have no crossovers.
So here's the criteria for the speakers:
- They don't need to play loud at all, moderate volumes in most any situation.
- I don't want to deal with building a crossover just yet, so I'm opting for a full range driver instead.
- They need to look GOOD. My house is clean, minimal, and for the most part devoid of anything gaudy in appearance.
- My preference for speaker sound is warm and laid back. (Think B&W Loudspeaker midrange...)
With all of that in mind, here's what I've come up with so far... I started by the generally positive word of mouth on this driver:
http://www.partsexpress.com/pe/show...-848&vReviewShow=1&vReviewRand=697993#reviews
Some people say the highs need to be tamed, but I think I'll build and then test to see if I find a notch filter necessary. I went ahead and plugged the driver's specs into WinISD and came up with a comfortable compromise cabinet volume of 938 cubic inches. (15.37 liters) This includes the thickness of 3/4 MDF on all sides...
Starting with "golden rule" dimensions, I then used a 3D program called Cinema 4D to tweak the shape. I used an awesome plug-in (demo version) called PhyTools that has the ability to calculate the internal volume of any polygonal shape I could come up with. It allowed me to view, in real time, the shape of the box changing and still meet my volume requirement.
WinISD gave a recommended port length of roughly 6 inches at 2.5 inches to meet the 70hz tuning point of the driver.
So at this point, I have a few questions before I get started...
- I would prefer to have these speakers front ported, since they'll need to be close to the wall, but is my angled port going to interfere by being too close to the bottom of the cabinet. (See one of the attachments for the wire frame side view)
- This is a smallish speaker to be sure (14.78 inches tall, 7.03 inches wide at the front, 10.03 inches long–this does not include the plint attached at the base) but should I still have some bracing in the middle?
- Most importantly, am I going about this the right way? Am I missing anything obvious at this stage of the game?
Here are the renders I came up with for the speaker design btw. I'm not sure if I like my stand designs because their shapes are so organic in contrast to the speaker's angular characteristics. If anyone sees any red flags, lemme know. Any efforts are appreciated.
Look very sleek & sexy - getting the paint to look as good as the render could be interesting.
Independent of any changes to the "organic" shape of the stand's upright members, I'd trim the top plate to slightly smaller footprint than the base of the enclosure.
Of course, your query could easily become a dialog on choice of driver,(particularly if you're looking for warm and laid back presentation with metal coned driver in a near field position) or construction material, so to avoid that, I'd make a couple of suggestions:
EnABL treatment to driver cone, perhaps even some extra gloss coat damping - the titanium cone could probably use all the help it could get, particularly in a small room.
Use a flared port, and even though an MDF cabinet of this size should be fairly well "damped", a holey vertical brace firmly engaging the driver magnet to the back of the enclosure would be worth considering.
Thanks for the suggestion on the stand. That'll be simple to impliment.
I won't be listening to these very closely. In fact, I'd estimate my ears will be sitting about 13 feet away from the speakers.
I was considering this port and just choping it down. It's flared as you suggested.
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=260-478
I did a quick search on "EnABL"ing the driver and found the monster thread... looks like I have some reading to do...
Thanks for the reply!
This same driver has popped up a couple times. The aggressive resonance this driver exhibits probably gives it a fair degree of listener fatigue (a guess -- i haven't heard them).
And a notch filter may give a flat gross FR but it will never fix the problem.
dave
dave
I like the straight forward honesty. 🙂
I searched for the driver in these forums and thus far only found tests on the driver as opposed to a speaker built with it. Maybe I should keep digging.
Would there be another full range go-to driver that doesn't have the flawed characteristics of the driver I was looking at? I'd like to keep it in the same size (3 to 4 inch range) and I'd prefer not to spend too much since is my first build (maybe $40-$60 each) and who knows how badly this may turn out. 🙂
Thanks again everyone.
The trouble with many fullrange drivers is that they frequently require a notch filter to get rid of a resonance, and generally need a BSC (unless they're mounted in a wall). They normally sacrifice either low frequency extension (and have greater bass distortion than similarly sized woofers) and/or sacrifice high frequency dispersion and have limited power handling. So I think you won't be able to avoid at least building some type of filter to overcome these problems.
Zaph has tested a number of small drivers here http://www.zaphaudio.com/smalltest/. I suspect for your application the less expensive TangBand (W3-1364S) could be a good choice. Other inexpensive choices include the AuraSound NS3 (available at Madisound) and the HiVi B3s or HiVi B3N. I've built the Zaph designed fullrange project based on the B3S utilizing a B3N (see http://www.zaphaudio.com/audio-speaker18.html). However the drivers sacrifice bass and really need a powered subwoofer for louder volume levels. But as a high quality, cheap starter project, they're excellent. As a plus the HiVi drivers are a very good looking copper color and could be a good match for your beautiful-looking renderings above. [Note that Zaph's project is a sealed box and ported enclosures would not be suitable for the B3N/S or AuraSound NS3 due to their higher Qts figures].
Re: Laid back drivers
gurley123 said:
I've heard (word of mouth only) that these guys sound pretty easy on the ears.
4" http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=264-846
3" http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=264-844
Dave, any plans for a micro-mini-Onken with the CSS FR125? That would be a sweet bedroom speaker.
Cool! I'll plug those in next (looks like they'll model very similarly to the others...).
Reading the reviews, they sound like they match my listening tastes better than the others I had initially stumbled upon.
Thanks for the tip.
planet10 said:
What kind of amp are you going to use with them?
dave
That I haven't decided yet. Most likely it'll be a solid state, but it'll probably need to be an amp that gives off little to no heat since it'll be inside a closed cabinet. (see picture below for speaker placement and the cabinet. NO, the speakers won't be quite that big...^_^)
Thanks for all the feedback!
http://www.kchtenthusiasts.com/web_pics/hui_k/hk47_6.jpg
Wow, all this feedback so soon is amazing. I'll go through and read up on everything you noted here. Thanks again!
Chirpie - no chance you'll run out of suggestions on this forum - just don't be surprised at the "animated" discussion and tangents that even a simple inquiry such as your original post can inspire.
If you've not already written your shortlist of amplifiers, you should certainly not overlook the latest cadre of class T amps. The Trends T10.1, and Kingrex T20U are 2 that I've heard in my own systems that certainly bear looking into.
There are also other flavors of drivers to be considered that fit both your budget and application, and of course more enclosure designs than you can imagine.
Full disclosure: I am a member of the Planet10 design/development team, and have been involved in the assembly of prototypes and direct sales versions of several of the cabinet designs on that website.
BTW, nice piece of graphic editing on post#10
I'm not Dave, but I don't think there's been any recent updates to plans for the CSSFR125 drivers.
If I may so bold, the Fostex FE127E in mFonken should make for a more than adequate small room speaker. Indeed with powered sub, such as the new CSS SDX7, these could more than hold their own as a main system.
While some of this is true, a lot has been left out. 1st, a notch filter is not always required, and further aren't truly effective. To really deal with a resonance you need to ameriolate resonance issues mechanically. Have a look for posts by Mark McKenzie. He is the master at detecting and in many cases, dealing with resonances. He has gone thru a lot of TBs, so you may find he has touched on the titanium TB.
As to baffle step... a filter is not the only way to deal with bafflestep. It is something one needs to concern themselves with.
The 3" drivers mentioned are not really full-ranges -- they should be considered as mid-tweeters (and when they do a good imitation limited at the bottom as far as depth & level is concerned). Gregg the Geek has a published BR for the Aura 3" that probably gets awards for most bass out of a speaker this small.
Of this class of drivers the best one overall that i have heard is the Fostex FF85k. Plan on at least 1 woofer unless you are going to plop them on either side of your shiny new iMac.
The sweet spot for balance is probably the 4 1/2-5" driver. If you are willing to put up with a tall cabinet (ie BIB, or Harvey, or Mikasa, or Saburo) then bass into the low 40s can be had. That low with lots of impact is going to require a helper woofer. The high frequencies on these is extended enuff for most people, if not enuff a simple cap crossed supertweeter can add some sparkle, Smaller boxes (ie Milevea, Met, Frugel-horn, A126) still go pretty low. Standmounters like your visualizations probably good to the mid 60s at best. Keep in mind that some of the bigger cabinets take up no more of a footprint than the standmounters & the stands and some (ie the Met) probably have less visula footprint to boot.
Most of the less expensive drivers (ie <$100/pr) have some resonance issues. My favorite (FE126e & FE127e) are not immune, but a known methodology exists to make them a lot better.
dave
A note on the paint. Not sure if you already know this but I thought I'd put it anyway for other folks. If you seal whatever your painting first with a couple of coats of polyurthane (sanding between coats), then two coats of primer, two coats of color it will come out looking like you painted metal, and not wood. It looks NICE for not much work. I personally use rustoleum paint, the trick is a coat every 15min or so, or 24hr minimum between coats.
EEatKSU said:
If you seal whatever your painting first with a couple of coats of polyurthane (sanding between coats), then two coats of primer, two coats of color...
:up:
A good tread about paint, painting and equipment here
