I am working on a BD1000 that is really noisy on startup, after a couple minutes it seems to go away. The noise is seen only on the lower half of the signal, as you adjust the gain up the noise seems to head towards the zero cross point. I can see the noise on the input stages then it clears up. I'm not sure if one of the isolated supplies is failing or what.
cory
cory
