BCY89 Dual Transistor
Hi.
Has anybody got any BCY89 dual transistors that they don’t need?
I currently looking for 4 off them new or used.
I need some for my restoration project, a 1978 Electrocampaniet 25Watt Class A amplifier.
Does anybody know of any equivalent transistors?
I had a similar problem once. I took 2 Xistors with like specs, matched them and glued them together with epoxy adhesive. Not ideal, but OK until you get the real stuff. Alternately you could try the Analog SSM2210 which is in an 8 pin DIP or SO package. E
