Hi everyone!!
I'm having problems getting BC327-40/BC337-40.
Anyone knows a good replacement?
Thanx.
Thanx.
This is a very ordinary transistor but with a bit more current than usual. I doubt though that this is an important parameter.
You can replace these types with almost any transistor but if you explain more where in the design they are I can give you a more precise recommendation.
The "40" suffix means hfe more than 400 which could be tricky to find but it's not for certain that you need this. I have a bunch of BC550C and BC560C which may fit.
C = "40"
C = "40"
peranders said:
337 can take a bit more current but I doubt that this an issue.
How come the 327/337 can take more current than the
139/140??
327/337 are rated 500ma while the 139/140 are 1500ma..
And if I'm using the 139/140 do u think I'll need to bias them
harder than the 327/337?
Udi.
139/140??
You can probably have the same bias but the base current will be at least 4 times more so pay attention to this.udip said:And if I'm using the 139/140 do u think I'll need to bias them
I see no problem to use BC550/560 though, 15 mA => 225 mW => not too much
Forgive me for my ignorance in this area, but shouldn't higher
current capability should be a plus?
If I use the BC550/560 instead of the originals (BC327/337)
than I'll have less output current, am I wrong? so
why using weaker transistor will not cause problems?
Maybe It's my english (that is my second language), but when
u say "can take" a bit more current, you mean more driving capabilities, right?
Udi.
How heavy will your load be at the output? If you know that you will also know how much output current you will need. For a normal preamp application I'd say BC550/560 will do.udip said:If I use the BC550/560 instead of the originals (BC327/337)
Ok..Now I understand. My mistake.
You meant that either the 550 or the 337 will have
no problems biased with 15ma (225mw out of
500mw that BC550 can handle)...
I'm thinking of using a buffer at the output..a discrete one
I guess..
I just wanna make sure that the opamp will stay in class A.
Thanks..
Udi.
I guess..
Thanks..
Udi.
Another thing..maybe you can help..
The MAT02/03 duals are little bit expansive, so I'm thinking of
matching 550....Is hfe matching enough? or I shoould
also match other parameters?
Udi.
Udi.
I have for sale SSM2210 and SSM2220 which are the same as MAT but in DIL package.
You can use BC transistors with pretty good results especially since you have a DC-servo and matching is not totally necessary but it helps a bit to bring down PSRR some which is good when it comes to distortion.
Those MAT's have about 15-20 dB lower noise but this is rather unimportant becasue the nosie will be 0.6-1 uV => 120 dB S/N with those "bad" transistors.
udip said:I'm having problems getting BC327-40/BC337-40.
These pairs are good replacements for output devices in your preamp:
BC639/640
MPSA42/92
ZTX450/550
2N5401/5551
Milan
- Design & Build
- Parts
- BC327/337 replacements
