bbp kit's
Iv'e just managed to take some low res images of my latest project..bbp phono. (Built By Pete...)
I used the Williams Hart phono stage, which is an abosolute diamond....and made my own split rail power supply. The layout is straight forward and the enclosure is similar to Fast cat's design. I used some oak for the side's, as iv'e got l of bits laying around , and the front, back, top and base are an old sign from the skip. It just fitted the job..3mm thick
bbp images
Here we go...
caps
No the caps are bhc areovox.. did'nt see the need for cerefine's. The phono stage sound's a whole lot better than most commercaily made stages, even op amp stages . A local secondhand dealer had one for ages, it was only replaced with an audio research sp10...
