With a battery powered le monstre, will the virtual 0v point be at 13 or so volts with respect to ground?
If so do all source supplies and any bi amps have to come of this same battery to maintain this virtual ground through out? or as the batteries are floating will any earth ground in the system set the 0v point in between the batteries. Please help, I am having a logic failure.
Sorry, like this with caps on amp boards. In effect ground is the middle of 24v. How does this interact with any genuine earth grounds from other links in the audio chain, ( source, active x or other amps)? Cheers.
